9 Replies Latest reply on Feb 3, 2015 2:55 PM by JimHess
    Camera Calibration - which Profile to use?
    Modesto Vega Level 2
      This is a spin out of another thread in the forum - How do I avoid magenta discolouring?.
      I am using a Lr 5.7.1 on OS X Mavericks (10.9.5) and photos from 3 cameras - Nikon D600, Nikon D40, and Canon 450D - they all exhibit a very similar behaviour with RAW files described below, but it much more noticeable with the Nikons and very noticeable with the D600. I have been using Lr since version 3 (I think but I might have started with version 2, I cannot remember).
      By default I have always imported my RAW files leaving the profile under Camera Calibrations as Adobe Standard. I have been moderately unhappy with the results I was seeing in Lr, not with all the images but with quite a few of them; in a nutshell they don't as I envision them and they don't look the way they look in camera. With "the way the look in camera" I mean inspecting the histograms and clipping warnings.
      I am fully ware that Lr does not read the picture control settings of any camera, my Nikons have always being set to Standard.
      Below are 2 screenshots from a photo taken with the D600.
      1) Histogram with Adobe Standard profile
      2) After and before view, left "Adobe Standard" right "Camera Standard"
      There are 2 different images, the histogram is changed, the greens are render differently. I also know which one I'll pick for further work, the right image, the one with Camera Standard as the profile.
      Back to the question for this post: Camera Calibration, which Profile to use? (and why?)
        • 1. Re: Camera Calibration - which Profile to use?
          I am very surprised nobody has replied to this after 2 days. So please let me just give it a new angle.
          After some tinkering with photos in my catalog I have established using "Camera Standard" instead of "Adobe Standard" makes a difference significant enough to use it as my Default camera calibration profile. The main reason for this is that I don't have the time to check each photo on an individual basis.
          With this in mind I have 2 questions:
          1) How do I apply "Camera Standard" as my default profile under camera calibration?
          2) For me this effectively a new process, most of my catalog (up to 10,000 images) uses the old process, "Adobe Standard" profile. How can I easily separate which part of my catalog has been processed using the old process and which part of my catalog has been processed using the new process?
          Hopefully somebody can give some guidance.
          • 2. Re: Camera Calibration - which Profile to use?
            ssprengel Adobe Community Professional & MVP
            Which profile to use is a matter of personal taste, so why does it matter what other people use?  I use a variety of profiles depending on the subject matter and lighting and camera body, and over the years I have used either Adobe Standard or Camera Standard or a custom-created dual-illuminant profile as my default camera profile.  Currently it is Adobe Standard with my 7D Mark II.
            As to your question about making Camera Standard the default profile, you do it the same as customizing any other LR default:  by selecting an unedited photo, setting Camera Standard as its profile, then on the keyboard use Alt - Set Default…  (the button was Reset before pressing Alt) then confirm that you want to update the LR defaults to the current settings.
            I am not sure how to find photos with a particular camera profile but perhaps one of the filters in Library can do that, or a smart collection query.  I don’t have LR in front of me right now to try things, myself.
            • 3. Re: Camera Calibration - which Profile to use?
              If it is known that you always want a certain profile to be the default profile, then all you have to do is choose that profile and then set camera defaults under the Develop menu in the develop module. Any settings that you have adjusted will then become part of the default settings for that camera. So it's probably wise to make as few changes as possible because these settings will be applied to every image that you import, or every image that you reset.
              I am still using an older Nikon D90. Most of the time I prefer the Adobe Standard profile. But I have boosted sharpness a little and applied a little luminance noise reduction, and have turned on lens correction. Anything else that needs to be done I do manually.
              If you decide to change your camera defaults, the message can be a little disconcerting. At least it was to me. After you choose to set new defaults you will see the message that this change is not undoable. The wording bothered me at first. But the key word is NOT. So you can always go in and change the defaults. Take note that default settings are at the minimum camera model specific. And if you want, you can even make the defaults serial number specific and ISO specific. It's a matter of you deciding how precise you want things to be on the import.
              • 4. Re: Camera Calibration - which Profile to use?
                I am not sure I would agree with this statement without making some important qualifications.
                Camera profiles can be used for creative purposes, no disagreement there. However, I don't think this is the sole purpose of camera calibration and camera profile, isn't it? Jeff Schewe, who sometimes contributes to this forum, wrote in The Digital Negative "The profiles are designed to calibrate a particular camera model's particular colour rendering intent [...]. It's entirely possible that your particular camera might be a bit different from the one they profiled, so you might be able to make a customer profile for your camera that would produce a more accurate rending than what comes with Lightroom and Camera Raw"; the quote is taken from his section on Lightroom Camera Calibration and leads to conclude that the purpose of camera profiles is also to reproduce the colour rendering intent of camera.
                My point on the original post is that it seems that Camera Standard, with both my Nikons set to "Standard" picture controls, seems to better reproduce the colour rendering intent of both cameras, specially if greens are involved. All I am looking for is advice regarding best practice. This is absolutely non trivial from my point of view, best practice is not a matter of personal taste as I am sure you know. Insisting that default settings are best practice, I am not saying you are saying this, is not helpful.
                This is correct.
                I don't think this possible. I cannot find a way to do it with smart collections or the filter library. I'll keep experimenting.
                • 5. Re: Camera Calibration - which Profile to use?
                  I still have an old Nikon D40, humbler than the D90. The approach you described is the approach I used with both the D40 and inherited when I got a Nikon D600. For a while, I have been noticing that certain photographs I take with the D600 were not as good in Lightroom as they appear on camera, they simply did not appear to work on the computer. I though it was down to the usual considerations when assessing images through an uncalibrated camera display and so. At the same time I started noticing that this seems to happen with certain colours, greens for example, look at the screenshots in the original post. So I started reading and changing the profile to Camera Standard. The results where so surprising that I downloaded Capture NX-D to double check; sure enough Lightroom with Camera Standard was much closer to Capture NX-D or to what I saw on camera than Adobe Standard.
                  One day I decided to try the same with some old photos from the old Nikon D40, photos is had discarded because I thought they did not look right. Once again, I was surprised.
                  If you have the time and willingness, take a photo taken with the older D90, preferably something you have already edited, make a virtual copy, reset the virtual copy and change the profile to Camera Standard, and see what adjustments you need to make. I don't know what subjects you photograph, it might not work for you. It does not work for 100% of photographs I took, but curiously it works for many photographs I have discarded.
                  P.S.: I had taken some photos with a Canon, although not as many as with Nikon. Anything shot with the Canon appears as close with Adobe Standard as with Camera Standard.
                  • 6. Re: Camera Calibration - which Profile to use?
                    I have actually done that with both my D40 and my D90. In fact I have presets that I created that simply switch to different profiles. It makes it much quicker for me to compare and decide. Sometimes I find that I will use the Camera Portrait profile for some of my landscape photos because that profile enhances the shadows for me. But most of the time I use the Adobe Standard profile. There is no right or wrong profile. For quite a while I had my D90 defaults set to use the Camera Neutral profile. But it wasn't being consistent for me and I switched my default back to the Adobe Standard.
                    • 7. Re: Camera Calibration - which Profile to use?
                      D Fosse Adobe Community Professional & MVP
                      I work as photographer at an art museum, and obviously "correct" color is always an issue. For color-critical work I always include a ColorChecker in the shot - not to make profiles, but used as a first target for adjusting tone and color in Lightroom (some final tweaking is always necessary).
                      Anyway - my experience is that the Adobe Standard profile, for the Nikon D800, is the one that consistently requires the least amount of adjustments to get there. It may look "dull", but it is the most neutral of all the profiles, and that's what I need. I use the DNG Profile Editor for non-standard light sources only (fluorescent or LED).
                      I basically don't care what the camera LCD shows, except as a hint that my exposure is roughly right. The work starts when I have the shots up in Lightroom.
                      I'm not saying the other profiles are "bad". It's nothing personal, just business
                      • 8. Re: Camera Calibration - which Profile to use?
                        twenty_one wrote:
                        I work as photographer at an art museum, and obviously "correct" color is always an issue. For color-critical work I always include a ColorChecker in the shot - not to make profiles, but used as a target for adjusting tone and color in Lightroom.
                        Thanks, the only things I check on the camera LCD are histograms and clipping warnings, that tells me if my exposure is right and if I have missed something when selecting the exposure. At the moment, I am consistently experiencing that "Camera Standard" gives more "correct colours" than "Adobe Standard" on a Nikon D600. Maybe I should stick with that an stop asking questions.
                        • 9. Re: Camera Calibration - which Profile to use?
                          It's okay to ask questions. But it's also okay to choose a different profile as the default for a camera. There can be slight differences in sensors between your camera and the one Adobe used to create the profiles. As I indicated previously, there is no "right" profile. If the camera standard profile works better for the D600 then I would go ahead and create the defaults for that camera using that profile. I'm sure you understand that you can set camera defaults for every camera that you are using. In other words, changing the D600 default to using the camera standard profile isn't going to change anything for your other cameras. The default settings for each model are completely independent.
