3 Replies Latest reply on Feb 2, 2015 2:44 PM by A.T. Romano
    Premiere Elements 13 , Problems with new text/titles
    thomasd3280855
      Premiere Elements 13, bisher keine Probleme. Nachdem die Filmlänge etwa 15 Minuten beträgt immer größere Probleme Titel/texte einzugeben. Wartezeiten sind extrem lange oder Programm stürzt ganz ab.
        • 1. Re: Premiere Elements 13 , Problems with new text/titles
          A.T. Romano Level 7
          thomasd
          On what computer operating system is your Premiere Elements 13 running?
          Just to clarify the translation...
          Are you saying that when the video on the Timeline is 15 minutes in duration, adding a title from the program's Titler causes the program to crash?
          What are the properties of this 15 minute video, what are the project settings (please see Edit Menu/Project Settings/General and readings for Editing Mode,
          Timebase, Frame Size, and Pixel Aspect Ratio (even if the fields look grayed out)?
          Assuming a Windows computer, if you go to Device Manager/Display Adapters/, what is listed for video card/graphic card...is there more than one?
          Is the video card/graphics card up to date according to the web site of the manufacturer of the card?
          More questions later. Please review and consider and then we can discuss this further based on your reply.
          Thank you.
          ATR
          • 2. Re: Premiere Elements 13 , Problems with new text/titles
            thomasd3280855 Level 1
            High ATR,
            Computer running on Widows 7 ,64 Bit System, Service Pack 1, Processor AMD Phenom(tm) X4 945 3.00 Ghz;RAM 8 GB
            Grafikkarte: NVIDIA GeForce 8800 GT
            If the video on the timeline is longer than 10 minutes the problem will be remarkable. The response times adding a title is getting longer(2-15 seconds).
            As the video is now 18 minutes the response time is after each action(resizing of letters or any changes of the text) up to 30 seconds or the program crashes completely.
            Project settings are the following:
            General HD 1080i; 29,97frames/second; Video:1920v 1080 H, 30 fps
            Video: maximale Bittiefe, Dateiformat i-frame only mpeg, Kompressor MPRG i-Frame, Standbilder optimieren
            The video is a mixture  of full HD videos 1920x 1080 .mov and pictures up to 4608x3456 pixels.
            When the program crashes I remarked that the main memory RAM(8Gb) was fully used by the premiere program. Might there be a problem?
            Thank you for your service.
            thomasd
            Von: A.T. Romano
            Gesendet: Sonntag, 1. Februar 2015 23:55
            An: Thomas Deschler
            Betreff:  Premiere Elements 13 , Problems with new text/titles
            created by A.T. Romano <https://forums.adobe.com/people/A.T.+Romano>  in Premiere Elements - View the full discussion <https://forums.adobe.com/message/7151822#7151822>
            • 3. Re: Premiere Elements 13 , Problems with new text/titles
              A.T. Romano Level 7
              thomasd
              Your last post was very important.
              Based on it, I am favoring the problem going to a computer resource explanation.
              How many of those 4608x3456 pictures do you have in the project when the project deteriorates, slows, and then dramatically crashes?
              You are using 4:3 photos in a 16:9 project and pixel dimension far exceeding the project settings (1920 x 1080 16:9).
              In view of your details and in this particular case, I would ask you to perform the following mini test run...
              1. Crop and resize copies of your original photos to 1920 x 1080 16:9.
              2. Make two copies of your current project (File Menu/Save A Copy - save copies, each with a different name than original project). And then use the copies for this testing.
              a. Remove all the photos from the project and start adding your titles to the project...is the workflow smoother?
              b. Leave everything as before but replace your 4608 x 3456 photos with the cropped resized 1920 x 1080 16:9 ones. Is the workflow smoother than before with the
              4608 x 3555 4:3 ones.
              ATR
