5 Replies Latest reply on Feb 1, 2015 5:37 PM by A.T. Romano
    Export scale issue - Premiere Elements 13
    CTgraphy
      When I export my video, clips which have been Scaled (In Applied Effects) are not matched to the ratio of the rest of the clips. How do I fix this?
      Here is a screen grab showing the problem. The clip is supposed to be zoomed in so the model's eyes are not showing. Instead the whole thing is super-imposed over the letterboxing.
      Thank you!
        • 1. Re: Export scale issue - Premiere Elements 13
          A.T. Romano Level 7
          ctgraphy
          Premiere Elements 13..This is probably a mismatch of settings.
          Let us explore...
          What computer operating system and what project settings (See Edit Menu/Project Settings/General and readings for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio
          even if the fields look grayed out.)
          What were your export settings
          Publish+Share
          Computer
          and then what
          and then what preset
          Did you customize the preset selected or use the default settings for it?
          Any question or need clarification, please do not hesitate to ask.
          Thank you.
          ATR
          • 2. Re: Export scale issue - Premiere Elements 13
            CTgraphy Level 1
            Hello! Here are the settings currently used.
            PC
            Windows 7 Classic
            Editing Mode: 1080i (grey)
            Timebase: 29.97 frames/second (grey)
            Frame Size: 1920 horizontal 1080 vertical
            Pixel Aspect: Square Pixels 1.0 (grey)
            Export for Computer -
            QuickTime
            Preset: NTSC DV
            No customization
            • 3. Re: Export scale issue - Premiere Elements 13
              A.T. Romano Level 7
              ctgraphy
              The basic issue that I am seeing is you taking a 16:9 project into a 4:3 export.
              If you want a DV.mov file as the export, then select the Publish+Share/Computer/QuickTime with Presets = NTSC DV 16:9 and let us know
              the results.
              We may have to do more fine tuning, but.....
              ATR
              • 4. Re: Export scale issue - Premiere Elements 13
                CTgraphy Level 1
                Thanks! Here are the results.
                The letterboxing top and bottom has disappeared. Now the image is stretching too much vertically. Black bars appear on either side of images which are not Scaled.
                • 5. Re: Export scale issue - Premiere Elements 13
                  A.T. Romano Level 7
                  ctgraphy
                  We need to go back to the beginning and evaluate
                  a. properties of source media imported into the project -
                  video compression
                  audio compression
                  frame size
                  frame rate
                  interlaced or progressive
                  file extension
                  pixel aspect ratio
                  b. does the project preset set (1080i30 - 1920 x 1080 @ 29.97 interlaced frames per second) match the properties of your source media
                  c. before you leave the Edit area are there any black borders showing in the monitor there?
                  c. are the export settings consistent with the project settings?
                  Please supply the information first for "a", and we will suggest the rest.
                  Do you have an export requirement...MPEG2.mpg, AVCHD.mp4, or H.264.mov? What frame size do you
                  want for the export - 1920 x 1080 16:9 or do you really want a SD rather than HD export?
                  We will be watching for further details.
                  Thanks.
                  ATR
