8 Replies Latest reply on Feb 23, 2007 1:18 PM by michaelmuller
    webservice error
    michaelmuller Level 1
      Anyone ever see this when using a webservice?
      Fatal Error: URI=null Line=2: The document type declaration for root element type "html" must end with '>'.
      org.xml.sax.SAXException: Fatal Error: URI=null Line=2: The document type declaration for root element type "html" must end with '>'. at org.apache.axis.utils.XMLUtils$ParserErrorHandler.fatalError(XMLUtils.java:723) at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source) at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source) at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source) at org.apache.xerces.impl.XMLScanner.reportFatalError(Unknown Source) at org.apache.xerces.impl.XMLDocumentScannerImpl.scanDoctypeDecl(Unknown Source) at org.apache.xerces.impl.XMLDocumentScannerImpl$PrologDispatcher.dispatch(Unknown Source) at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source) at org.apache.xerces.parsers.XML11
      This is a webservice that runs via multiple incarnations of the same code... different domains all pointing to the same code base, but pulling from different dbs and content folders. The ws works fine on all sites tested, except for one site. I've tested the method by calling it as a component and there doesn't appear anything untoward in the output (with no errors when called as a comp).
      Thoughts?
      Googling the error brings up 30 hits, about 20 of which are on blogspot, and this one:
      http://www.w3.org/Bugs/Public/show_bug.cgi?id=2471
      I'm carnfused.
      Michael
        • 1. Re: webservice error
          This is part of the message as well..
          Could not generate stub objects for web service invocation.
          • 2. Re: webservice error
            bump
            • 3. Re: webservice error
              Level 7
              Are you 100% positive that you are correctly connecting to the web service?
              Glancing at your error, the first thought that came to my head was that
              a IIS error page or some other unexpected content is being returned. In
              my experience this content has never been well formed XML and throws
              errors like this when a process tries to use it as such.
              Other then that idea more information about the web service and how you
              are calling it would help.
              • 4. Re: webservice error
                Abinidi Level 1
                Try clearing out the /stubs folder and rerun the service. Maybe one of the cached WS is corrupt.
                • 5. Re: webservice error
                  This is how I'm calling it:
                  <cfinvoke
                  webservice=" http://xxxxxxx.com/_xxxxxxx.cfc?wsdl"
                  method="getFTPInfo"
                  returnvariable="xxx">
                  <cfinvokeargument name="userName" value="xxxxx">
                  <cfinvokeargument name="userPassword" value="xxxxx">
                  </cfinvoke>
                  <cfdump var="#xmlParse(xxx)#" label="getFTPInfo">
                  <cfcatch type="Any">
                  <h1>Error</h1>
                  <cfdump var="#cfcatch#">
                  </cfcatch>
                  </cftry>
                  The error is thrown by the first CFDUMP. Here's the "Detail" at the top of the caught dump:
                  Name: http://xxxxxx.com/_xxxxxxxxxx.cfc?wsdl. WSDL: http://xxxxxxx.com/_xxxxxxxxxxxx.cfc?wsdl. org.xml.sax.SAXException: Fatal Error: URI=null Line=2: The document type declaration for root element type "html" must end with '>'. It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
                  When I look at the _xxxxxxxxxx.cfc?wsdl as suggested, in the browser, it loads fine. No hassles.
                  If I call the method via componant, thusly:
                  <cftry>
                  <cfinvoke
                  component="_xxxxxxxxx"
                  method="getFTPInfo"
                  <cfinvokeargument name="userName" value="xxxxxx">
                  <cfinvokeargument name="userPassword" value="xxxxxx">
                  </cfinvoke>
                  <h1>Error</h1>
                  </cfcatch>
                  </cftry>
                  It works fine, no errors.
                  As mentioned above, this exact service works on other domains (all running the same code base on the same server, just coming in via different domains and calling data from different dbs)
                  My first thought was that the info being sent back may have some illegal characters, but that's not the case. See code snippet below to see the kind of data that is being sent back.
                  Abinidi I did clear the /stubs folder and no change. Also went into the Administrator and saw that this ws hadn't yet been registered there.
                  • 6. Re: webservice error
                    Just to make sure you understand, this code works fine on other instances, ie; all I have to do is change the domain name, un and pw to another site and it works fine. It's just this one site's instance that is giving me trouble. All it can be then is the data, right? Or perhaps something's up with the internals that is causing an error, which manifests as the xml error we see above... but that can't be true since I can call it as a component and I get no errors with the same exact un/pw data.
                    • 7. Re: webservice error
                      Level 7
                      </cfinvoke>
                      <cfouput>#xxx#</cfoutput>
                      What do you get if you just output xxx. Is it the expected result and
                      is it well formed xml?
                      • 8. webservice error
                        Never gets there. Apparently the call itself is having a problem. Here's the error (below).
                        If I change the url and un/pw (which, again, is going to the exact same code, just a different db) I get no error. Here's the output, unparsed:
                        <?xml version='1.0'?><alldata><userpassword>xxxxxx</userpassword> <ftp_user>xxxxxx</ftp_user><siteactive>1</siteactive><status>OK</status><username>xxxxxx< /username> <ftp_server>xxxxxxx.com</ftp_server> <siteroot> http://xxxxxx.com/d0001/LocalUser/xxxxxxx/</siteroot><hostactive>1</hostactive> <ftp_password>xxxxxxxxxxxx</ftp_password> <hostname>Muller Technologies, Inc.</hostname><siteid>239</siteid></alldata>
