0 Replies Latest reply on Feb 2, 2015 7:12 AM by Hellenique
    Text outside textfield, warning pop-up export to certified PDF
    Hellenique
      I have a question about the "export to certified pdf" action. When in Indesign (CS 6) you have to much text in your textfield and it wont fit, you get an error message in the bottom. If you do decide to "export" it anyway (PDF), you will get a warning pop-up saying there is text standing outside the textfield. Instead of the "export" action you can also choise to use the "export to certified PDF" action. In this case the warning popup wont show up because the PDF is directly send to het certification program (I'll use Connector). Is there a way that you can activate the warning pop-up also for the "export to certified PDF" action?
      Kind regards Henrie van Beek
