1. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
JJMack Feb 2, 2015 11:20 AM (in response to caxton25) -
2. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
caxton25 Feb 3, 2015 1:55 AM (in response to JJMack)Thank you JJ Mack. Do you know what I should do now I have found the fault?
3. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
JJMack Feb 3, 2015 5:38 AM (in response to caxton25)Can not see what is on your machine what do you see on your machine?
4. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
caxton25 Feb 4, 2015 12:42 AM (in response to JJMack)I have solved the problem by going to Edit/Prefrences and unticking the Use graphics card box. All is now working normally.
Thanks for your time.
5. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
JJMack Feb 4, 2015 4:36 AM (in response to caxton25)That most likely mean your display driver needs to be updated to a newer version. If you use windows got to the Web site of the manufacture of the display adapter you have in you machine and download the latest driver. If you have a Mac check Apple support.
6. Re: After a few minutes my Photoshop CC dispays this mesage PHOTOSHOP CC HAS STOPPED WORKING AND NEEDS TO CLOSE. I have updated the graphics driver and restarted several times to no avail. This has happened before but I can't seem to fix it. I have an HP
caxton25 Feb 4, 2015 6:54 AM (in response to JJMack)I updated my display driver to the latest version last week when I first encountered the problem. This seemed to cure things until it reappeared on Monday evening. Apparently this is a problem that seems to affect HP computers. The worse thing being is that you never know when they release updated drivers for your system unless you look for them yourself.
