6 Replies Latest reply on Feb 10, 2015 5:24 PM by elaineg94828332
    Multiple graphic frames: resize, fit content proportionally, center content
    elaineg94828332
      Hello scripting wizards! I'm hoping one of you can help me with this simple task. How I wish actions were an option! I've read the posts saying how simple apple scripting is. I've read the tutorial from start to finish and done the exercises. I've copied snippets from multiple sources and the only thing I've been able to do is fit content ... but not proportionally.
      I'm using INDD CC. I have a dozen tabloid size pages with a hundred placed illustrator images on each. Here's what I need to do to every one of graphic frames:
      1. make all the graphic frames the same size: 10mm x 10mm
      2. fit content to frame proportionally
      3. center content in frame
      Can anyone help? Thanks!
        • 1. Re: Multiple graphic frames: resize, fit content proportionally, center content
          Kevin Parrott Level 2
          Hi
          this should get you moving in the right direction
          tell application "Adobe InDesign CC 2014"
              activate
              set myDoc to active document
              tell myDoc
                  set transform reference point of layout window 1 to center anchor
                  set geometric bounds of rectangles of active layer to {0, 0, 10, 10}
                  fit rectangles of active layer given center content
                  fit rectangles of active layer given proportionally
              end tell
          end tell
          • 2. Re: Multiple graphic frames: resize, fit content proportionally, center content
            elaineg94828332 Level 1
            Thank you; it's SO close! Everything works great, except the frames all align at the top left of the window (0,0) instead of staying where they are on the page.
            I unsuccessfully tried replacing set transform ... and set geometric ... with the following:
            resize rectangles in geometric path bounds from center anchor by replacing current dimensions with values {10, 10 [, mm]} but that didn't do it.
            I also found a seemingly relevant snippet but I'm not sure how to use it:
            set {a, b, c, d} to geometric bounds
            set geometric bounds to {a, b, (c + 10), (d + 10)}
            • 3. Re: Multiple graphic frames: resize, fit content proportionally, center content
              Hi Kevin,
              After dogging this all day yesterday (and the day before) I was a bit delirious last night when I said that "everything works except ..." It successfully resizes the frame and fits content to frame, but does not center the content in the frame or leave the frame where it is. Any ideas?
              • 4. Re: Multiple graphic frames: resize, fit content proportionally, center content
                hi Elaine
                being playing around with this script, It might just be my settings here, but I cant get it to work in mm
                so I have changed it to work in points, so 28.3464567 = 10mm, see how this works for you.
                    activate
                    tell myDoc
                        tell view preferences
                            set ruler origin to page origin
                            set horizontal measurement units to points --millimeters (couldnt get it to work using mm)
                            set vertical measurement units to points --millimeters
                        end tell
                        set theRects to rectangles of myDoc
                        repeat with i from 1 to count of theRects
                            set MyNewSize to item i of theRects
                            resize MyNewSize in geometric path bounds from center anchor by replacing current dimensions with values {28.3464567, 28.3464567}
                        end repeat
                    end tell
                end tell
                • 5. Re: Multiple graphic frames: resize, fit content proportionally, center content
                  forgot to replace the view preferences with the original view prefs.
                      activate
                      tell myDoc
                          set OrigViewPrefs to properties of view preferences
                          end tell
                          end repeat
                              set horizontal measurement units to horizontal measurement units of OrigViewPrefs
                              set vertical measurement units to vertical measurement units of OrigViewPrefs
                          end tell
                      end tell
                  end tell
                  • 6. Re: Multiple graphic frames: resize, fit content proportionally, center content
                    Hi Kevin,
                    Those dang millimeters! The script I came up with defaulted to pixels of all things. So my solution (actually two scripts) isn't pretty but it works though it paints with a wide brush ... every rectangle. I hope to add a repeat line like yours so I can select only the ones I want. A blogger out there in Scripter Land sent me some ideas of how to combine and improve them; I hope to dig into their logic soon. These are the two I came up with:
                    Resize frame 10mm x 10mm
                      activate
                      tell active document
                      resize every rectangle in inner coordinates from center anchor by replacing current dimensions with values {30, 30}
                      end tell
                    end tell
                    Fit content to frame (proportionally and centered)
                      activate
                      tell the active document
                      tell every rectangle
                      fit given content to frame
                      fit given proportionally
                      fit given center content
                      end tell
                      end tell
                    end tell
