• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Error Handler (File not Found) missing .cfm
Engaged ,
Feb 22, 2007 Feb 22, 2007
I have multiple applications on my server. For each application I would like an error handler that will catch missing .cfm files. If a user types in www.abc.com/test.cfm, and test.cfm does not exist, each site will use its own "errorHandler.cfm" file for example.
I already can handle .htm and .html files in IIS, basically when the 404 error happens, it calls my html error handler. I also tried checking the option in IIS where you see a list of file extensions, you go to .cfm (this is all in IIS), and there is a checkbox that says "check if file exists", so I have checked and unchecked this, but not luck.
In CFAdmin there is an area where you can specify a missing template handler. This seems to apply to the whole server. Each of our application are very different, I would like to have an individual error handler in each application.
I am getting a CF error, (File not Found) not an IIS error when you type a file in the url string as mentioned above. I tried using <cferror> in my Application.cfm file, but to no avail. I tried using try/catch to no avail. I have heard of others having this frustration as well.
Help is greatly appreciated
-Westside
TOPICS
Advanced techniques
Views
295
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Feb 23, 2007 Feb 23, 2007
I've not tried this, but consider having the server-wide error handler look at the CGI.HTTP_REFERER variable to see what application threw the error. Then do a <CFLOCATION> to the application-specific error handler.
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Also remember that this setting ONLY applies if the page missing was referenced by a <cfinclude> tag
- Mike
Votes
Translate
Translate
Report
Report
Resources
Documentation
