4 Replies Latest reply on Feb 6, 2015 8:56 PM by Chinnadk
    How to findout the achored text frame based on label and remove?
    Jackkisten Level 1
      Dear All,
      how to findout the anchored text frame based on Label [ex: textFrame.label = "ABC"] and remove this particular anchor frame. please suggest me.
      regards,
      Jack
        • 1. Re: How to findout the achored text frame based on label and remove?
          Sajeev Sridharan Level 4
          Try this,
          for (var idx = 0; idx < app.activeDocument.allPageItems.length; idx++)//this line will search all page items
              var pageItem = document.allPageItems[idx];
              if(pageItem.label == "ABC")
                  pageItem.select();
                  pageItem.remove();
          Vandy
          • 2. Re: How to findout the achored text frame based on label and remove?
            @vandy88 – did you test your code?
            @Jack – if I get this right, you have three conditions:
            1. The object you want to remove is a TextFrame
            2. The TextFrame is anchored
            3. The TextFrame is labeled with a String: "ABC"
            Other conditions?
            Like: The TextFrame could be part of a group, that itself is anchored?
            Before iterating over all page items available, I think it would be better to iterate on all Stories and their text frames (textContainers) and check:
            1. Is the parent of the text frame a character? => THEN it's anchored
            2. And is there a label reading "ABC" ?
            If both conditions are met, remove the text frame.
            The question is: Should we do it immediately?
            Or should we mark it somehow and the user could decide on a later step to remove it?
            OR MAYBE BETTER:
            Do a GREP search on anchored objects by script and check, if the found item is a text frame and is labeled "ABC".
            The found anchor character is a texts object and inherits the text frame (or a different object).
            //Note: The variable myFoundCharacter is not defined yet.
            myFoundCharacter.pageItems[0].getElements()[0];
            would reveal the true nature of the anchored object.
            Of course the situation could be more difficult, because the labeled text frame could be part of a group, part of a nested object, that itself is anchored…
            Uwe
            • 3. Re: How to findout the achored text frame based on label and remove?
              Jackkisten Level 1
              Hi Uwe,
              Anchored textFrame, if contain the label value "ABC" should remove all. i think you got my point.
              Regards,
              ~jack
              • 4. Re: How to findout the achored text frame based on label and remove?
                Chinnadk Level 4
                Is this you need?
                var doc = app.activeDocument,
                    _stories = doc.stories;
                for(var i =0;i<_stories.length;i++)
                        var pi = _stories[i].textFrames;
                        for(var j=pi.length-1 ;j>=0;j--)
                                if(pi[j].parent instanceof Character && pi[j].label == "ABC")
                                         pi[j].remove();
                Regards,
                Chinna
