5 Replies Latest reply on Feb 5, 2015 12:28 PM by Qwertyfly...
    duplicating multiple groups?
    mgraphix99 Level 1
      Hello all,
      I am attempting to develop a script where i have a selection of a group and it would duplicate twice along the x axis.  Then, take all the grouped items and duplicate it down the y axis 3x.
      This is what i have so far:
      var myNeckLabel = myDoc.selection[0];
      // For loop duplicating selection, moving to the left 2x
      for (var sel=0; sel<[2]; sel++){
        myNeckLabel.duplicate();
        myNeckLabel.translate(-3.9327*72);
      // For loop duplicate selection down 3x
      for (var sel=0; sel<[3]; sel++){
        myNeckLabel.translate(0,-3.153*72);
      What the above produced for me is the desired effect, except it will only do it down the left column, so i would have the top row and the left column filled out. how do i select every object the first loop creates and then feed it into the second loop?
      Thanks for the help in advance !
        • 1. Re: duplicating multiple groups?
          Qwertyfly... Level 4
          my solution was to group the top row then continue
          var newSelection = myDoc.selection;
          var newGroup = myDoc.groupItems.add();
          for(var i = 0; i < newSelection.length; i++)
              newSelection[i].move(newGroup,ElementPlacement.INSIDE);
            newGroup.duplicate();
            newGroup.translate(0,-3.153*72);
          • 2. Re: duplicating multiple groups?
            mgraphix99 Level 1
            Thanks imagecollection ! putting into a group worked.
            this is what i ended up doing with the code:
            var totalMatrix = app.getScaleMatrix(-100,100);
            var allSelected = myDoc.selection;
            var wholeGroup = myDoc.groupItems.add()
            for (var i = 0; i < allSelected.length;i++)
                allSelected[i].move(wholeGroup,ElementPlacement.INSIDE);
            app.activeDocument.activeLayer.pageItems[0].transform(totalMatrix);
            By chance do you know what the best way for me to do this without grouping everything into one massive object?
            I tried aciveDocument.selectObjectsOnActiveArtboard(true);  but it didn't work out.
            Thanks again for the help
            • 3. Re: duplicating multiple groups?
              Does this do what you want?
              var doc = app.activeDocument;
              var sel = doc.selection;
              dup(sel,0,2,-3.9327*72,0);
              for(var i = 0; i < sel.length; i++)
              dup(sel,i,3,0,-3.153*72);
              for(var j = 0; j <sel.length; j++)
              sel[j].transform(totalMatrix);
              function dup(sel,item,qty,tran1,tran2)
              for (var i=0; i<[qty]; i++){
                sel[item].duplicate();
                sel[item].translate(tran1,tran2);
              • 4. Re: duplicating multiple groups?
                mgraphix99 Level 1
                That it does, perfectly actually. Pure genius imagecollection ! Thank you !
                • 5. Re: duplicating multiple groups?
                  Glad I could help.
