2 Replies Latest reply on Mar 20, 2007 1:51 AM by ankmit
    Line Chart Issue
    CAIWorks_Kevin
      I have a simple line chart that has four line series. There are a series of controls that allow the user to filter the data that feeds each of the line series, thus adjusting the lines within the chart. However, if the data returned for the first line series is a zero (0), ALL of the lines disappear from the chart. If a zero value is returned for any of the other line serires (2-4), the chart behaves correctly by displaying the remaining lines that have data.
      Has anyone experienced anything like this? If so, is there a fix/work around for this?
      Thank you in advance for any help.
      Kevin
        • 1. Re: Line Chart Issue
          rikenpatel
          hi,
          i think after getting data for all series u have to check whether data for all the series is available or not. if the data for first series is not available then make the second line series as first series for ur chart and so on.
          • 2. Re: Line Chart Issue
            ankmit
            this generaly happens when the filter conditions specified do not fetch any data
            on a particular combination ie: neither zero nor null
            for eg if any one of the series item is city and it is set to such a name which is not present in the dataset than this may make the line chart behave in the way you said
