1 Reply Latest reply on Feb 4, 2015 5:36 AM by resdesign
    Supersized
    Giraf_Raf
      Hello,
      Do you think that is possible to make responsive background like "supersized" (Supersized - Full Screen Background Slideshow jQuery Plugin) The image will be resized in proportion but when the window of the browser is not the same prop the image will increase... I tried to do that in edge but I still have border inside or downside the window.
      If is not possible to "emulate" what supersized do... is it possible to use supersized plugin directly in Edge ?
      Thank a lot
      Raff
        • 1. Re: Supersized
          resdesign Adobe Community Professional & MVP
          Hey Raff,
          Many plugins are OK in EA. You just need to read their API to understand how to apply it. Also make sure you add any dependency like jquery if needed and in the right order. If jquery is needed then it must be first in the list in the script panel.
          Now, I suppose you probably could make it work in EA on it's own using css for your div
          sym.$('divName').css( {
             " background-image":"url('images/imageName.jpg')",
              "background-repeat":"no-repeat",
            "background-size":"cover"
          Hope this helps.
