8 Replies Latest reply on Mar 8, 2018 12:52 PM by frameexpert
    How to access the Publisher module
    Arnis Gubins Adobe Community Professional & MVP
      Does anybody know if the Publisher module is exposed to FM's Extendscript (or FDK)? I looked through all of the scripting info and the FDK info, .h and config files and couldn't find any references to it other than the TPUBforFMDoc (Book/DITA  esc ph shortcut) command. I need to kick off the Publish module after some manipulation and use a specified STS file depending upon the manipulation.
        • 1. Re: How to access the Publisher module
          Mike-Hardy Level 3
          It might expose an interface to F_ApiCallClient(). But there is nothing documented in the "Calling Clients" chapter of the FDK Reference Guide, And I don't believe there's any easy way even to determine whether it is using this mechanism, let alone to capture or reverse-engineer any commands being used. So I guess this is a non-starter..
          Another possibility is a scripted playback of keyboard shortcuts.
          • 2. Re: How to access the Publisher module
            Thanks for looking into this Mike. I'm pretty certain that it's a client call to the FMPublisher.dll, but what message is required and what return codes are generated is the mystery. I guess the powers that be are afraid that someone will start cloning the FMServer functionality and impact their (perceived) revenue stream. I also note that the latest FrameScript version also has nothing about accessing the Publish routines.
            The keystroke scripting is a good idea, but on further thought wouldn't work that well, as different STS files and output locales would need to be used depending upon prior outcomes, so pre-configuring all of the possible combinations would be a wee bit of a maintenance challenge and would be installation dependent.
            • 3. Re: How to access the Publisher module
              Thanks to the Adobe engineering team in India, here's a sample script showing how to call the FMPublisher client using a pre-defined STS file in order to generate one of Responsive HTML5, WebHelp, ePub, Kindle or CHM outputs:
              /***************************************************************************************** Function to set STS *************************************************************************
              Input1:- Path of sts to be set  (if path contains backward slashes, each slash character should be masked with another backward slash)
              e.g. stsPath = C:\\Users\\username\\Desktop\\settings.sts*/
              function SetSts(stsPath)
                  var strCommand="SetMCPSetting "+ stsPath ;
                var ret=CallClient ("FMPublisher", strCommand );
                  return ret;
              /***************************************************************************************** Function to set BASE OUTPUT LOCATION of the publish outcome *************************************************************************
              Input1:- Base Output Path to be set  (if path contains backward slashes, each slash character should be masked with another backward slash)                       */
              function SetBaseOutputLocation(outputPath)
                  var strCommand="SetOutputLocation "+ outputPath ;
                  return ret;
              /*********************************************************************** Function to Publish *******************************************************************************
              Input1:- Base Output Path to be set  (Output parameter is one of these values: Responsive HTML5, WebHelp, EPub, Kindle, Microsoft HTML Help)       */
              function PublishOutput(output)
                  strCommand="MCPPublish "+output ;
                  var ret=CallClient ("FMPublisher", strCommand);
                  return ret;
              function doGenerateOutput()
                  var stsPath = "C:\\Users\\username\\Desktop\\Settings.sts";
                  var outputPath = "C:\\Users\\username\\Desktop\\Output";
                  var output = "Responsive HTML5";
                  SetSts (stsPath);
                  SetBaseOutputLocation (outputPath);
                  PublishOutput (output);
              doGenerateOutput ();
              • 4. Re: How to access the Publisher module
                frameexpert Level 4
                Hi Arnis, Excellent! Thanks for posting this. Have you had a chance to test it? Thanks. -Rick
                • 5. Re: How to access the Publisher module
                  frameexpert Level 4
                  Hi Arnis,
                  I haven't been about to get this to work and wonder if I am missing a parameter or something: Here is my code with FrameMaker 12 and ExtendScript:
                  #target "framemaker-12.0"
                  var stsFile = "C:\\Program Files (x86)\\Adobe\\AdobeFrameMaker12\\fminit\\Publisher\\Default.sts";
                  var folder = "C:\\DATA\\Scripts\\HTML5";
                  // Set the sts path.
                  setSts (stsFile);
                  setOutputFolder (folder);
                  publishOutput (output);
                  function setSts (stsFile) {
                      var cmd = "SetMCPSetting " + stsFile;
                      alert (cmd);
                      return CallClient ("FMPublisher", cmd);
                  function setOutputFolder (folder) {
                      var cmd = "SetOutputLocation " + folder;
                      alert (cmd);
                  function publishOutput (output) {
                      var cmd = "MCPPublish " + output;
                      alert (cmd);
                  All the paths and files are correct, but I don't get any progress bars or output. Any help would be appreciated. Thanks.
                  Rick
                  • 6. Re: How to access the Publisher module
                    frameexpert Level 4
                    It actually IS working. I had the output path wrong. I am sorry for the confusion. You may mind my code a little more concise than Adobe's. Make sure you remove the alert statements before using it. Thanks.
                    • 7. Re: How to access the Publisher module
                      Apollo102 Level 1
                      very good helpful script.
                      Are there hints for further commands? I would like to select the dita file to be published (via script). In the list of the pod you always have all open files, which could be manually selected.
                      However, I only found the additional command SetDitaval. SetFilePointer I also could see.
                      Does anyone have an idea.
                      Thank you
                      Apollo102
                      • 8. Re: How to access the Publisher module
                        frameexpert Level 4
                        Is there a way to set the input file or book using the CallClient ("FMPublisher") function? Thanks.
