1 Reply Latest reply on Feb 5, 2015 10:47 AM by thunderJ
    Has anyone successfully registered a web services running ColdFusion 11 with Windows 7, IBM WebSphere 8.5, IBM 1.7 JDK
    thunderJ
      I'm setting up a Windows 7 development box running IBM WebSphere 8.5 (64-bit), IBM 1.7 JDK (64-bit). I have installed the ColdFusion 11 ear (11,0,03,292480) file, but when I try register a web services in the ColdFusion Adminstrator using both Web Service Version 1 or 2 I get the following error.
      Error 500: java.lang.UnsupportedClassVersionError: JVMCFRE003 bad major version; class="com"/sun/tools/javac/Main, offset=6
      From what I have read online (Java Errors: “UnsupportedClassVersionError…bad major version at offset=x” - The Altogether) the "java.lang.UnsupportedClassVersionError:" and "bad major version" mean that the project was compiled with a higher level Java compiler than the runtime can support. I am running the IBM 1.7 JDK, when I do a version check (java.exe -version) in the bin directory it says it is based on Oracle 7u13-b08. I have read ColdFusion 11 supports Java 1.7 so I am not sure what the problem is.
        • 1. Re: Has anyone successfully registered a web services running ColdFusion 11 with Windows 7, IBM WebSphere 8.5, IBM 1.7 JDK
          thunderJ Level 1
          Problem solved! I found the following documentation: Installing the JEE Configuration - Enable web services
          Enable web services
          To enable web services, copy the tools.jar file from Java home that WebSphere uses to the cfusion/lib directory.
          I'm not completly sure why I needed to do this as everything worked fine in ColdFusion 9, WebSphere 7 IBM, IBM 1.6 JDK. There must be a biggest enough difference between the IBM 1.7 JDK/SDK and Oracle/Sun 1.7 JDK/SDK.
          The manifest information in the tools.jar packaged with ColdFusion 11 says:
          Manifest-Version: 1.0
          Created-By: 1.7.0_07 (Oracle Corporation)
          As where the manifest information from the tools.jar I copyied in was:
          Ant-Version: Apache Ant 1.7.1
          Created-By: 1.7.0 (IBM Corporation)
          Class-Path: ibmorbtools.jar
          I renamed the old file to tools.jar.bk-non-ibm as it is important not to have a file with a ".jar" extention that has the same class path inside of it or it will get loaded by the JVM.
