3 Replies Latest reply on May 27, 2015 2:12 PM by Lille Ulven
    Lightroom 5.7 unable to export or edit in
      I keep getting a message that says: Unable to Export An Internal Error has occurred: ?:0:attempt to index a nil value.  I am using Lightroom 5.7 and Photoshop CC 2014 on a Mac with OS10.7.5
      Also, my Edit In Options are all greyed out.  All of this was working fine 2 days ago and seemed to coincide with a corrupted catalog.
      I have tried the following:
      -  Deleted the LR preferences
      -  Re-Installed LR
      -  Deleted & Re-Installed PS CC 2014
      Please help!!!
        • 1. Re: Lightroom 5.7 unable to export or edit in
          Geoff the kiwi Adobe Community Professional & MVP
          I the Export Menu at the bottom, check the Post-Processing section. Make sure the "After Export" choice isn't blank. Choose "Do Nothing".
          • 2. Re: Lightroom 5.7 unable to export or edit in
            susang4377310 Level 1
            Thank you Geoff, but that it was already set to Do Nothing.  Unfortunately, I cannot find a solution other than creating a new user on my Mac and then both LR & PS are behaving perfectly...this is challenging though as I'd have to direct the new user at all of my apps and files and this is quite complicated.
            • 3. Re: Lightroom 5.7 unable to export or edit in
              Lille Ulven
              You don't happen to have a backup on a different hard drive, do you? (OK, you may have found your solution already as this thread is a couple of months old...but then maybe my workaround will help someone encountering the same difficulties later on)
              I just had the very same error - after my original catalogue got corrupted and actually several repair-attempts (and copying the backup file into the original directory) finally resulted in an apparently working catalogue... I could not export any files but got instead this error message:
              An internal error has occurred: ?:0: attempt to index a nil value
              (Mac OS 10.10.3, LR5.7)
              It seems though that the repair-attempts also resulted in a corrupted hard drive (which I thought to have fixed with the Mac Hard Drive tool).
              What eventually saved me was: I opened the backup catalogue in LR in its backup-directory. No problem with any type of nil-value during export.
              So workaround for now:
              1. Daily backups on a different hard drive
              2. Remembering this and hoping to always find the latest backup.
              Best of luck
