2 Replies Latest reply on Mar 14, 2007 7:42 AM by SamC2
    Suppress Play Button in Template
    SamC2 Level 1
      The "Play" button dominates the "Next" button in all presenter templates. Students get disoriented when "Play" is accidently pressed.
      Is there a way to suppress "Play" by editing the template XML shell?
      Sam
        • 1. Re: Suppress Play Button in Template
          asm0d
          If you're familiar with Flash and Actionscript, you can use a Flash module to modify the player (which is just another Flash module itself). Try including this Actionscript on a button (or something else the user would have to click) that you drop in at the start of your PPT presentation:
          _root.m_controlBar.m_playBtn._visible = false;
          This will disable the play button for the duration, but is sort of a "hack" and totally unsupported by MacroDobe.
          By the way, if you change it to:
          _root.m_controlBar.m_playBtn._onRelease();
          it simulates pressing the play button - you can use this to programmatically control the Breeze player.
          The other controls are:
          m_volumeBtn
          m_attachmentsBtn
          m_slideBackBtn
          m_slideNextBtn
          m_playBtn
          m_viewChangeBtn
          m_scrubBar
          v/r
          Marc B
          • 2. Re: Suppress Play Button in Template
            SamC2 Level 1
            Mark,
            Thanks for the feedback. I'm on leave, but will give this a try this weekend.
            Sam
