6 Replies Latest reply on Feb 20, 2007 10:18 AM by Newsgroup_User
    line breaks in dynamic text?
    Level 7
      I have some text that goes into a dynamic text box and I would like to
      break it. I would like to break it after the first sentence. I thought
      the <br> might do it, but it seems not like this?
      bodyCopy.errorText.text = "Username and password do not match.<br>Please
      re-enter your username and password.";
      Thank you!
        • 1. Re: line breaks in dynamic text?
          Level 7
          Brian,
          > would like to break it. I would like to break it after the
          > first sentence. I thought the <br> might do it, but it seems
          > not like this?
          Make sure your dynamic text field is set to a) Multiline and b) enabled
          for HTML.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: line breaks in dynamic text?
            Level 7
            David, thanks!
            I know have the html enabled, but it still treats the <br> as part of
            the text.
            This is what I have:
            Thank you for the help!
            Brian
            • 3. Re: line breaks in dynamic text?
              Level 7
              Brian,
              > part of the text.
              Make sure the text field is also set as Multiline, rather than Single.
              > bodyCopy.errorText.text = ...
              Woops, I missed that before. The TextField class (which defines dynamic
              and input text fields) provides two text-related properties: text and
              htmlText. When you're using HTML as your text, use the latter:
              bodyCopy.errorText.htmlText = "<p>tags here<br />and here</p>";
              David Stiller
              • 4. Re: line breaks in dynamic text?
                Level 7
                I just followed the manual directly like this:
                bodyCopy.errorText.html = true;
                bodyCopy.errorText.multiline = true;
                />Please re-enter your username and password.";
                And still am having the problem. What could be the issue? I also set the
                text box to html enabled and multililne, could the two be conflicting?
                Thank you!
                • 5. Re: line breaks in dynamic text?
                  Level 7
                  Brian,
                  > bodyCopy.errorText.text = "Username and password do not match.<br />Please
                  That's almost right.
                  > I also set the text box to html enabled and multililne, could
                  They're not conflicting, but you need to add your HTML text to the
                  object's htmlText property, not the text property.
                  bodyCopy.errorText.htmlText = // tags here
                  David Stiller
                  • 6. Re: line breaks in dynamic text?
                    Level 7
                    David,
                    great, got it working. Sorry, did not see your response before posting
                    my second one. But it is all working now!
                    Thanks a lot!!!
                    B
