9 Replies Latest reply on Feb 9, 2015 8:42 PM by creativejoan0425
    UI dialog error ( Cannot handle request because a modal dialog or alert is active)
    creativejoan0425 Level 1
      I have a dialog which only can run when u select cell, after showing the dialog, I click check1 it will popup another dialog and close the previous dialog, but when I press "enter", I will alert "Cannot handle request because a modal dialog or alert is active", and cannot run the dialog 2 action
      // start myGet Columns Info ---------------------------------------------
          //now col width
          var mySelColWid = app.selection[0].cells[0].width;
      // end of myGet Columns Info ---------------------------------------------
      myDisplayDialog2_new();
      function myDisplayDialog2_new(){
      //w1 ----------
          var w = new Window("dialog", "Adjust Col._v1.0");
                w.alignChildren = "left";
          var g = w.add ("group");
          var check1 = g.add ("checkbox", undefined, "Figure Col.?");
                 check1.value = true;
          var g2 = w.add ("group");
          var panel = g2.add("panel");
                 panel.orientation = "column";
          var my1row = panel.add("group");
                my1row.orientation = "row";
                my1row.alignment = "left";
                my1row.add ("statictext", undefined, "Col. Width:");
                var myText = my1row.add ("edittext", undefined, mySelColWid);
                      myText.characters = 7;
                      myText.active = true;
          var my5row = panel.add("group");
                my5row.orientation = "row";
                my5row.alignment = "left";
                my5row.add ("button", undefined, "Ok", {name: "ok"});
                my5row.add ("button", undefined, "Cancel", {name: "cancel"});
      //w1 ----------
      check1.addEventListener ("click", function ()
          w.close();
          myDisplayDialog3_new();
      var myWindow1 = w.show();
           if( myWindow1 ==true){
                  app.selection[0].cells.everyItem().width = 100;
      function myDisplayDialog3_new(){
      //w2 ----------
      var w2 = new Window("dialog", "Adjust Col._v1.0");
              w2.alignChildren = "left";
      var gA = w2.add ("group");
      var check1a = gA.add ("checkbox", undefined, "Text Col.?");
             check1a.value = false;
      var gB = w2.add ("group");
      var panelA = gB.add("panel");
             panelA.orientation = "column";
      var my1row = panelA.add("group");
            my1row.add ("statictext", undefined, "Test Width:");
            var myText_w2 = my1row.add ("edittext", undefined, mySelColWid);
                  myText_w2.characters = 7;
                  myText_w2.active = true;
      var my7row = panelA.add("group");
            my7row.orientation = "row";
            my7row.alignment = "left";
               my7row.add ("button", undefined, "Ok", {name: "yo"});
              my7row.add ("button", undefined, "Cancel", {name: "no"});
      //w2 ----------
      check1a.addEventListener ("click", function ()
          w2.close();
          var myWindow2 = w2.show();
          if (myWindow2 == true){
              try{app.selection[0].cells.everyItem().width = 50;
              catch(e){alert(e);}
        • 1. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
          This appears to be a scripting question, so I've moved it to the scripting forum.
          • 3. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
            Loic.Aigon Adobe Community Professional
            You want to check if your dialog returns 1 but actually returns nothing => w.close();
            try w.close(1);
            Loic
            http://ww.ozalto.com
            • 5. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
              I have this feeling you are overcomplicating stuff here but maybe I just didn't got the idea. If your intention is to "redraw" the UI when user picks one choice or the other, the same can be achieved more simply
              function main(defaultWidth) {
                var w = new Window ("dialog", "Adjust Col._v1.0" );
                var tp = w.add('panel', undefined, "Choose target to apply width…" );
                var dd = tp.add('dropdownlist',undefined, ["Text", "Col"]);
                var vp = w.add('panel', undefined, "Set width value…" );
                var ti = vp.add('edittext', undefined, defaultWidth );
                var btnGp = w.add('group');
                var koBtn = btnGp.add('button', undefined, "Cancel");
                var okBtn = btnGp.add('button', undefined, "OK");
                btnGp.orientation = "row";
                btnGp.alignment = "fill";
                btnGp.alignChildren = ["fill","right"];
                tp.alignment = "fill";
                dd.alignment = "fill";
                vp.alignment = "fill";
                ti.alignment = "fill";
                dd.selection = 0;
                koBtn.onClick = function() { w.close(0); }
                okBtn.onClick = function() { w.close(1); }
                if ( w.show() == 1 ) {
                alert( "you want to apply "+ti.text+" on "+dd.selection.text );
              main(500);
              HTH
              Loic
              http://www.ozalto.com
              • 6. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
                In fact I want to have 2 window, cause I didt jus have one option for the text and col
                for example text I may have 3 different button and col hv 5 different button, so I want to switch different dialog
                • 8. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
                  I would choose to stay in the same view. But it's easy to redraw some parts on the UI given user interaction. In this example, depending on what radiobutton user selects youc an hide/display differents UI components.
                    var rbGp = w.add('group');
                    var rb1 = rbGp.add('radiobutton',undefined, "X");
                    var rb2 = rbGp.add('radiobutton',undefined, "Y");
                    var rb3 = rbGp.add('radiobutton',undefined, "Z");
                    rb1._id = "rb1";
                    rb2._id = "rb2";
                    rb3._id = "rb3";
                    rb1.value = true;
                    rbGp.alignment = "fill";
                    var _sel = rb1.text;
                    var optGp = w.add('group');
                    optGp.orientation = 'stack';
                    optGp.alignment = "fill";
                    optGp.alignChildren = ["left", "fill"];
                    var st1 = optGp.add('statictext',undefined, 'Set X…');
                    var st2 = optGp.add('statictext',undefined, 'Set Y…');
                    var st3 = optGp.add('statictext',undefined, 'Set Z…');
                    st2.visible = st3.visible = false;
                    var f =  function(e){
                     var id = e.target._id;
                     st1.visible = id=="rb1";
                     st2.visible = id=="rb2";
                     st3.visible = id=="rb3";
                     _sel = e.target.text;
                    rbGp.addEventListener ( 'click', f, true);
                    alert("You want to edit "+_sel+" property" );
                  main(500);
                  HTH
                  Loic
                  • 9. Re: UI dialog error ( Cannot handle request because a modal dialog or alert is active)
                    How about this one?
                        //defined the Text Frame Width
                        var myDocWidth = app.activeDocument.documentPreferences.pageWidth
                        var myDocActuralWidth = Math.round (myDocWidth);
                        var myLeftPageMargin = app.activeWindow.activePage.marginPreferences.left;
                        var myRightPageMargin = app.activeWindow.activePage.marginPreferences.right;
                        var myTextFrameWidth = myDocActuralWidth - myLeftPageMargin - myRightPageMargin;
                        //end of defined the Text Frame Width
                        //now col width
                        //now col left indent
                        var mySelColLIndnet = app.selection[0].cells[0].leftInset;
                        //now col rigt indent
                        var mySelColRIndnet = app.selection[0].cells[0].rightInset;
                        //now table indent
                        var mySelTabIndnet = app.selection[0].parent.storyOffset.leftIndent;
                       // now tab position and have leader or not
                        var mySelColNumberTabStops = [];
                        var mySelTextContents = [];
                        var mySelColTextTabStops = [];
                        var mySelTableColumns = app.selection[0].columns[0].cells.everyItem().texts.everyItem().getElements();
                        for (var a=0; mySelTableColumns.length >a; a++){
                            mySelColNumberTabStops.push(mySelTableColumns[a].tabStops.everyItem().position);
                            mySelTextContents.push(mySelTableColumns[a].contents);
                            mySelColTextTabStops.push(mySelTableColumns[a].tabStops.everyItem().leader);
                        if(mySelColNumberTabStops.toString().match(/[\d]/)){
                            var mySelColTabPosition =  mySelColWid-Math.round(app.selection[0].cells[0].texts[0].tabStops[0].position);
                        else{
                            var mySelColTabPosition =  0;
                        if(mySelTextContents.toString().match(/\t,/) && mySelColTextTabStops.toString().match(/ \./)){
                            myLeaderBoolean = true;
                        else {
                            myLeaderBoolean = false;
                        //now text indent
                        var myTextIndentBoolean = app.selection[0].cells.everyItem().texts.everyItem().firstLineIndent;
                        if(myTextIndentBoolean.toString().match(/-/)){
                            myTextIndentBoolean = true;
                        else {
                            myTextIndentBoolean = false;
                         //now Symbol our of margin
                        var myEachColTabStops = [];
                        var mySelTableColumns = app.selection[0].cells.everyItem().texts.everyItem().getElements();
                            myEachColTabStops.push(mySelTableColumns[a].tabStops.everyItem().alignmentCharacter);
                        if (myEachColTabStops.toString().match(/[*#@^(]/)){
                            myTabStopsOMCheck = true;
                        else {
                            myTabStopsOMCheck = false;
                    myCellDialog1();
                    function myCellDialog1(){
                        var my2row = panel.add("group");
                              my2row.orientation = "row";
                              my2row.alignment = "left";
                                my2row.add ("statictext", undefined, "1n Col.:");
                                var myColArray = [];
                                var mySelTableColumns = app.selection[0].parent.columns.everyItem().getElements();
                                    myColArray.push(Number(a+1).toString());
                        var myDropdown = my2row.add ("dropdownlist", undefined, myColArray);
                              myDropdown.itemSize = [66,20];
                              myDropdown.selection = 0;
                        var my3row = panel.add("group");
                              my3row.orientation = "row";
                              my3row.alignment = "left";
                              my3row.add ("statictext", undefined, "Tab Position:");
                              var myTabPosition = my3row.add ("edittext", undefined, mySelColTabPosition);
                                    myTabPosition.characters = 6;
                                    myTabPosition.active = true;
                        var my4row = panel.add("group");
                              my4row.orientation = "row";
                              my4row.alignment = "left";
                        var mySymbol = my4row.add ("checkbox", undefined, "*#@^( out of Margin");
                              mySymbol.value =  myTabStopsOMCheck;
                            w.close();
                            myCellDialog2();
                        if (myWindow1 == true){
                       alert("apply window1 value");
                    function myCellDialog2(){
                                var g = w2.add ("group");
                                var check1a = g.add ("checkbox", undefined, "Text Col.?");
                                var g2 = w2.add ("group");
                                var my1row_w2 = panel.add("group");
                                      my1row_w2.orientation = "row";
                                      my1row_w2.alignment = "left";
                                      my1row_w2.add ("statictext", undefined, "Col. Width:");
                                      var myText_w2 = my1row_w2.add ("edittext", undefined, mySelColWid);
                                      my3row.add ("statictext", undefined, "Col. Indent (L):");
                                      var myColLIndent = my3row.add ("edittext", undefined, mySelColLIndnet);
                                            myColLIndent.characters = 5;
                                            myColLIndent.active = true;
                                      my4row.add ("statictext", undefined, "Col. Indent (R):");
                                      var myColRIndent = my4row.add ("edittext", undefined, mySelColRIndnet);
                                            myColRIndent.characters = 5;
                                            myColRIndent.active = true;
                                var myTextIndent = my5row.add ("checkbox", undefined, "Text Indent");
                                       myTextIndent.value = myTextIndentBoolean;
                                var my6row = panel.add("group");
                                      my6row.orientation = "row";
                                      my6row.alignment = "left";
                                var myLeader = my6row.add ("checkbox", undefined, "Leader");
                                       myLeader.value = myLeaderBoolean;
                                var my7row = panel.add("group");
                                      my7row.add ("button", undefined, "Ok", {name: "ok"});
                                      my7row.add ("button", undefined, "Cancel", {name: "cancel"});
                                    w2.close();
                                    myCellDialog1();
                                alert("apply window2 value");
