0 Replies Latest reply on Feb 6, 2015 11:21 AM by creativejoan0425
    UI dialog error ( Cannot handle request because a modal dialog or alert is active)
    creativejoan0425 Level 1
      I have a dialog which only can run when u select cell, after showing the dialog, I click check1 it will popup another dialog and close the previous dialog, but when I press "enter", I will alert "Cannot handle request because a modal dialog or alert is active", and cannot run the dialog 2 action
      // start myGet Columns Info ---------------------------------------------
          //now col width
          var mySelColWid = app.selection[0].cells[0].width;
      // end of myGet Columns Info ---------------------------------------------
      myDisplayDialog2_new();
      function myDisplayDialog2_new(){
      //w1 ----------
          var w = new Window("dialog", "Adjust Col._v1.0");
                w.alignChildren = "left";
          var g = w.add ("group");
          var check1 = g.add ("checkbox", undefined, "Figure Col.?");
                 check1.value = true;
          var g2 = w.add ("group");
          var panel = g2.add("panel");
                 panel.orientation = "column";
          var my1row = panel.add("group");
                my1row.orientation = "row";
                my1row.alignment = "left";
                my1row.add ("statictext", undefined, "Col. Width:");
                var myText = my1row.add ("edittext", undefined, mySelColWid);
                      myText.characters = 7;
                      myText.active = true;
          var my5row = panel.add("group");
                my5row.orientation = "row";
                my5row.alignment = "left";
                my5row.add ("button", undefined, "Ok", {name: "ok"});
                my5row.add ("button", undefined, "Cancel", {name: "cancel"});
      //w1 ----------
      check1.addEventListener ("click", function ()
          w.close();
          myDisplayDialog3_new();
      var myWindow1 = w.show();
           if( myWindow1 ==true){
                  app.selection[0].cells.everyItem().width = 100;
      function myDisplayDialog3_new(){
      //w2 ----------
      var w2 = new Window("dialog", "Adjust Col._v1.0");
              w2.alignChildren = "left";
      var gA = w2.add ("group");
      var check1a = gA.add ("checkbox", undefined, "Text Col.?");
             check1a.value = false;
      var gB = w2.add ("group");
      var panelA = gB.add("panel");
             panelA.orientation = "column";
      var my1row = panelA.add("group");
            my1row.add ("statictext", undefined, "Test Width:");
            var myText_w2 = my1row.add ("edittext", undefined, mySelColWid);
                  myText_w2.characters = 7;
                  myText_w2.active = true;
      var my7row = panelA.add("group");
            my7row.orientation = "row";
            my7row.alignment = "left";
               my7row.add ("button", undefined, "Ok", {name: "yo"});
              my7row.add ("button", undefined, "Cancel", {name: "no"});
      //w2 ----------
      check1a.addEventListener ("click", function ()
          w2.close();
          var myWindow2 = w2.show();
          if (myWindow2 == true){
              try{app.selection[0].cells.everyItem().width = 50;
              catch(e){alert(e);}
