9 Replies Latest reply on Feb 23, 2007 3:48 AM by Newsgroup_User
    path to cfc
    Dinghus Level 1
      I have tried what the documentation says to do but can't get this to work.
      How do I call CFCs that reside in a folder above the current folder?
      The documentation says just to use the path but use dots instead.
      So com.cfcs.mycfc But this doesn't work.
        • 1. Re: path to cfc
          Level 7
          "doesn't work".
          Can you elaborate on that? What - exactly - happens to make you think it
          doesn't work? And what - exact - code are you using which causes this?
          Adam
          • 2. Re: path to cfc
            BKBK Adobe Community Professional & MVP
            Show us the directory structure of the cfm page and of the cfc. Otherwise, it's difficult to say.
            Suppose your cfc is someDirStructure/com/cfcs/mycfc.cfc. Then the code
            <cfset obj = createObject("component","com.cfcs.mycfc")>
            will work if you put it in any of the following pages
            someDirStructure/testPage.cfm
            someDirStructure/com/testPage.cfm
            someDirStructure/com/cfms/testPage.cfm
            arbitraryDirStructure/testPage.cfm (if you have declared a "com" mapping in the Coldfusion Administrator)
            • 3. Re: path to cfc
              Level 7
              i think Dinghus is asking about a case when
              cfc is in someDirStructure/com/cfcs/mycfc.cfc
              and createObject script is in a page in
              someDirStructure/com/anotherDir/yetAnotherDir/testPage.cfm
              or maybe even
              someDirStructure/anotherDir/yetAnotherDir/testPage.cfm
              will reference com.cfcs.mycfc still work from those locations?
              Azadi Saryev
              Sabai-dee.com
              http://www.sabai-dee.com
              • 4. Re: path to cfc
                Level 7
                no, you should provide the full path to the CFC
                (someDirStructure.com.cfcs.mycfc). someDirStructure should be off the web root &
                of course web accessible. or better yet use cf mapped dir.
                • 5. Re: path to cfc
                  someDirStructure should be off the web root & of course web accessible.
                  An important consideration my example only assumes, but should have stated explicitly.
                  • 6. Re: path to cfc
                    Level 7
                    CFCs don't NEED to be either in the webroot or web accessible, unless
                    they're being used as web services, do they?
                    Adam
                    • 7. Re: path to cfc
                      Level 7
                      I don't think they NEED to, but that the webroot is one of the
                      automatically searched paths if one does not have a mapping.
                      That is my understanding anyway.
                      • 8. Re: path to cfc
                        satbeh
                        here is the solution to it
                        You create a mapping in the cf Administrator for the topmost folder
                        and then you can access anywhere using the dot operators along with the mapping name
                        for example
                        if you have a cfc at the level -- "mainfolder/subfolder/nextsubfolder/required.cfc"
                        you need to create a mapping
                        say name = com , path = physical path to "mainfolder"
                        Now you can access the required.cfc by creating an object as follows--
                        <cfset obj = createObject("component","com.subfolder.nextsubfolder.required")>
                        Good Luck
                        • 9. Re: path to cfc
                          Level 7
                          if they're not in a cf mapped dir, custom tag dir, etc yes i think they do need
                          to be web accessible in one form or another. otherwise how would you find them?
                          created a CFC junk.cfc, tossed into c:\data on the server, data dir is *not* web
                          accessible.
                          <cfscript>
                          j=createObject("component","data.junk");
                          </cfscript>
                          "Could not find the ColdFusion Component data.junk."
                          if you don't use a cf mapped dir or one of its searched dirs, the CFCs need to
                          reside in web accessible dirs. maybe one of cf's classpaths will work but i
                          wouldn't let any tom, dick or harry mess around in those.
