3 Replies Latest reply on Feb 8, 2015 1:50 PM by JJMack
    batch action crop
    ssmithpi
      I've written a batch action to crop a native 2:3 Canon image down to a 4:3 slide show size of 1024x768.  The action appears to work but some of the resized images have areas of blank space where they were cropped when processed from Raws to large Jpegs before the downsize.
      Any thoughts?
        • 1. Re: batch action crop
          Could you be mixing in some portrait images into the batch. Handling Landscape and portraits in a batch process can be tricky.  Also portrait 2:3 images cropped to a landscape 4:3 aspect ratio will not work well the resulting cropped composition will most likely be very poor.
          • 2. Re: batch action crop
            ssmithpi Level 1
            Hi JJMack,
            thanks for the courtesy of your reply.  Your suggestion is indeed wise, but
            it isn't relevant to this case as all the original images were horizontals.
            • 3. Re: batch action crop
              You expand the action so you can read the steps and setting recorded. You may see something in what was recorded that explains what is happening. If you can not solve to problem.  Save the action set and upload it the the web and post a link to it. So I can download it and look at it.
