2 Replies Latest reply on Feb 21, 2011 2:26 PM by ChicagoGirl1980
    webservices and abstract types
    Level 7
      hi!
      i am trying to retrieve data from microsoft crm, to do this i need to use
      webservices. i can correctly connect but then i try to use the 'retrieve'
      function and it complains about a parameter.
      it seems to me cf wants to construct an abstract java class, which ofcourse
      fails. constructing the "com.microsoft.schemas.crm._2006.Query.ColumnSet"
      class via create object fails (the class i can use) because it can not be
      found.
      anyone had this error before or has some pointers about how to solve it?
      alwin
      --[ the error ]--
      Error converting CFML arguments to Java classes for web service invocation.
      Unable to create web service argument class
      com.microsoft.schemas.crm._2006.Query.ColumnSetBase. Error:
      java.lang.InstantiationException. Often this is because the web service
      defines an abstract complexType as an input to an operation. You must create
      an actual instance of this type in Java. The error occurred in
      D:\www\cs.alwin\crm\webserviceTest\account.cfm: line 12
      10 : username="-"
      11 : password="-"
      12 : returnVariable = "returnVar" argumentcollection="#arguments#">
      13 : </cfinvoke>
      14 : <cfoutput>#returnVar#</cfoutput>
      --[the code]--
      <cfset arguments = structnew() />
      <cfset arguments["entityName"] = "Account" />
      <cfset arguments["id"] = "3DB1F426-316F-DB11-8277-003048528AA5" />
      <cfset arguments["columnSet"] = structnew() />
      <cfset arguments["columnSet"].attributes = arraynew(1) />
      <cfset arguments["columnSet"].attributes[1] = "accountid" />
      <cfinvoke
      webservice = " http://myhost/mscrmservices/2006/CrmService.asmx?wsdl"
      method="Retrieve"
      username="-"
      password="-"
      </cfinvoke>
