2 Replies Latest reply on Feb 8, 2015 6:39 AM by MRaj01
    replace text with images
    MRaj01 Level 1
      I'm using a script found here, to replace @equ001.pdf@ with the corresponding image, same for eq002 etc.
      This script works more or less ok for me.
      Sometimes, it removes some image names without replacing the image, sometimes it was leaving some "@" here and there.
      Sometimes, it's giving me an error on the "place image" code, saying it cannot find the image, giving it's path ending with the grep expression $2 and doesn't work at all.
      Sometimes it does part of the job, stops, gives the same error as above, and continues to work when I click ok.
      Today, it didn't worked on a document. I copied the text to work on into a new InDesign document an there, it worked (but in two times).
      Is there any other way of doing this ?
      if(app.documents.length != 0){
          var myFolder = Folder.selectDialog ('Choose a folder with images');
          if(myFolder != null){
              // reset the Find/Change dialog
              app.findGrepPreferences = app.changeGrepPreferences = null;
              // formulate a grep search string
              app.findGrepPreferences.findWhat = '@.+?@';
              // find all occurrence, last one first
              f = app.activeDocument.findGrep (true);
              for (i = 0; i < f.length; i++){
                  // construct file name
                  name = f[i].contents.replace (/@/g, '');
                  // place the image
                  var placedObjects = f[i].insertionPoints[0].place (File (myFolder.fsName + '/' + name));
          // delete all @??@ codes
          app.activeDocument.changeGrep();
      else{
         alert('Please open a document and try again.');
