5 返信 最新の回答 日時: Feb 11, 2015 5:47 PM ユーザー:helpdesk113
    インストールでエラー
    helpdesk113
      OS:Windows7 Proffesional SP1 32bit
      アップデートの失敗した為、再インストールを試みているが
      内部エラーのウィンドウが出てインストールできない。
      ツールを使用し完全アンインストール後に実行しても同じエラーになる。
      AdobeSFX.LOGに下記のエラーが出ています。
      [2015-02-06 09:06:34] Adobe SFX 10.0.0.1 logging started.
      [2015-02-06 09:06:34] CommandParam CmdLine: "C:\Users\XXXXXXX\Desktop\AdbeRdr11010_ja_JP.exe"
      [2015-02-06 09:06:34] TempFolder: C:\Users\XXXXXXX\AppData\Local\Temp\
      [2015-02-06 09:06:34] Support folder: C:\Users\XXXXXXX\AppData\Local\Temp\25537
      [2015-02-06 09:06:34] Extracting: C:\Users\XXXXXXX\AppData\Local\Temp\25537\config.bin
      [2015-02-06 09:06:34] Found RDC resource and valid configuration information - setting RDC mode
      [2015-02-06 09:06:34] CheckSystemRequirements os,sp = 61 10 osString = 61W3, physicalMemory (1023) = 1024
      [2015-02-06 09:06:34] Adding extracted installer size to the total size: 146
      [2015-02-06 09:06:34] Adding extracted RDC size to the total size: 44
      [2015-02-06 09:06:34] CheckDiskSpace...
      [2015-02-06 09:06:34] Required size in MB:  270
      [2015-02-06 09:06:34] Available disk space in MB:  5639
      [2015-02-06 09:06:34] IsAlreadyInstalled...
      [2015-02-06 09:06:34] InitDialog...
      [2015-02-06 09:06:34] SetupInstaller...
      [2015-02-06 09:06:34] Extracting: C:\Users\XXXXXXX\AppData\Local\Temp\25537\installer.bin
      [2015-02-06 09:06:35] Extracting: C:\Users\XXXXXXX\AppData\Local\Temp\25537\RDC.bin
      [2015-02-06 09:06:35] Installer folder: C:\ProgramData\Adobe\Setup\{AC76BA86-7AD7-1041-7B44-AB0000000001}
      [2015-02-06 09:06:35] Extracting files from Archive: C:\Users\XXXXXXX\AppData\Local\Temp\25537\installer.bin
      [2015-02-06 09:06:45] Extracting files from Archive: C:\Users\XXXXXXX\AppData\Local\Temp\25537\RDC.bin
      [2015-02-06 09:06:52] StartInstaller...
      [2015-02-06 09:06:52] CreateProcess cmdLine: "C:\ProgramData\Adobe\Setup\{AC76BA86-7AD7-1041-7B44-AB0000000001}\setup.exe" /msi DISABLE_CACHE=1
      [2015-02-06 09:14:09] Installer finished with exit code: 1603
      [2015-02-06 09:14:09] Cleanup...
      [2015-02-06 09:14:10] Program finished with exit code: 1603
      メッセージ編集者: デスク ヘルプ
      以下のURLよりダウンロードしてインストールした場合 「Error 1359,内部エラーが発生しました。」になりました。
      http://www.adobe.com/support/downloads/detail.jsp?ftpID=5507
      メッセージ編集者: デスク ヘルプ
