Does anyone have any Idea what needs to be done to fix this problem. We have projects that we need to get to that are in captivate.
When I try to load Captivate version 3.0.1.589 on any of the 3 computers I have it installed on, I get the following message.
The Flash Player for Microsoft Internet Explorer, is not currently
installed on your computer.
You will automatically be redirected to the Adobe website in order to
download the Flash Player.
Please note that Adobe Captivate cannot be used until the Flash Player
is installed
The computer is windows 7 64 bit, 32 gig RAM
Captivate use to work fine on all 3 computers.
It has been installed and working for years with no problems on all 3 computers.
When I go to adobes flash tester for Internet Explorer, it says that I have version 16,0,0,305 installed.
https://www.adobe.com/swf/software/flash/about/flashAbout_info_small.swf
The captivate error message redirects you to install the Flash Player software again. I have re-installed the flash player on all three machines but it still gives the same error message.
Also there is a support page that suggest setting internet explorer to the default browser . I have set internet explorer as the default browser as suggested by the support, and followed the associated instructions.
Error: "Adobe Flash Player is not currently installed" when you start Adobe Captivate
Hi there
If you are seeing this when starting Captivate 3, likely you need to DOWNGRADE your flash player. The one you have is probably too new and Captivate 3 doesn't understand it.
Cheers... Rick
