2 Replies Latest reply on Feb 22, 2007 8:56 AM by Newsgroup_User
    Altering Colours
    ugureren34
      Hello Friends;
      I just start to use frieworks and i need to alter blue colours to red colours in an area that i have cropped on a pic.
      Please help me. Please explain clearly.
      Kind Regards;
        • 1. Re: Altering Colours
          Level 7
          Can you post a link to the image? Or maybe a similar one ...?
          alex
          ugureren34 wrote:
          > Hello Friends;
          > Kind Regards;
          • 2. Re: Altering Colours
            Level 7
            If you are selectively trying to replace colors, you can try the Replace
            Color Tool. The results may be enough to satisfy your needs.
            From the FW help files:
            To replace one color with another by selecting a color on the image:
            Select the Replace Color tool from its pop-up menu.
            In the From box in the Property inspector, click Image.
            Click the To color well in the Property inspector to select the color
            probe, then select a color from the pop-up menu.
            Set the other stroke attributes in the Property inspector:
            Size sets the size of the brush tip.
            Shape sets a round or square brush tip shape.
            Tolerance determines the range of colors to replace (0 replaces only the
            To color; 255 replaces all colors similar to the To color).
            Strength determines how much of the Change color is replaced.
            Colorize replaces the From color with the To color. Deselect Colorize to
            tint the From color with the To color, leaving some of the From color
            intact.
            Using the tool, click down on a section of the bitmap image that
            contains the color you want to replace. Without lifting the tool,
            continue to brush across the image with it. The color that you clicked
            down on when you initiated the brushing action will be replaced by the
            color you’ve specified in the To color well.
            Jim Babbage - .:CMX:. & .:Adobe Community Expert:.
            Community MX
            Extending Knowledge, Daily
            http://www.communityMX.com/
            .:Adobe Community Expert for Fireworks:.
            news://forums.macromedia.com/macromedia.fireworks
            news://forums.macromedia.com/macromedia.dreamweaver
            > alex
            > ugureren34 wrote:
            >> Hello Friends;
            >> colours in an area that i have cropped on a pic. Please help me.
            >> Kind Regards;
