Hi I have been trying to edit live stream with DVR enabled. Whenever i try to record a live stream in Editor application (also from ADOBE FMS tools) i get this error StreamNotFound.
Offline videos under the Source directory are being edited just fine. here are the steps i am following
1. Stream video with stream name 'livestream' from Adobe Media Encoder (checked on DVR Auto Record)
2. Strat DVR with DVRControllerSync.swf
3. Check if the DVR enabled stream is playable in Web with saple Video Player
4. In Editor Flex application set in point and out point and Generate On_demand clip.
A flv file gets created but always 21 Kb , with no content in it.
On server on log i get this
2015-02-10 | 11:40:03 | 6704 | (i)2611173 | Event level recording configuration: General[flags: 1, keyframe interval: 60000, max size: -1, max length: -1, io buffer size: 0], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100.000000, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000, disk management with gap: false, max sample descriptors: 3], ContentProtection[enabled=false(overridable)] | - |
2015-02-10 | 11:40:03 | 6704 | (s)2641173 | : NetStream.Data.Start | - |
2015-02-10 | 11:40:03 | 6704 | (s)2641173 | : NetStream.Publish.Start | - |
2015-02-10 | 11:40:03 | 6704 | (s)2641173 | : NetStream.Play.StreamNotFound | - |
2015-02-10 | 11:40:03 | 6704 | (s)2641173 | : NetStream.Play.Stop | - |
2015-02-10 | 11:40:14 | 6704 | (s)2641173 | : NetStream.Record.Stop | - |
