1 Reply Latest reply on Feb 25, 2007 11:05 PM by Ivascu Cristian
    Can't get across bridge
    odyssey27 Level 1
      I can't get anything to work beyond getting an instance of root. This is very frustrating!!! Any help, please???
        • 1. Re: Can't get across bridge
          Ivascu Cristian Level 1
          You are getting the javascript error that txtTest is not a function because the syntax for calling elements of the root movie has changed. Now you have to do it like this:
          var test = root.getTxtTest().getText();
          alert(test);
          and it will work just OK. To access a component of your flash movie always prepend get before the actual ID and capitalize the first letter. Thus, if you have a slider with the id slide1, you can access it like this:
          var mySliderProperty = FABridge.movie_name.root().getSlide1().getProperty;
          Only root can be accessed directly by calling root() on the flash movie. All other controls must follow this rule.
          Hope this helps,
          Cristian
