1 Reply Latest reply on Feb 11, 2015 8:30 PM by KoMaruyama
    why sequence name is difference. _[9999]or{9999}
    haikabuti
      I import sequence file named temp_0000.png~temp_0100.png,
      usually file name  is temp_[0000-0100].png on AE project panel.
      but now  I receive some AE.aep files include  temp_{0000-0100}.png.
      what is {} ? it's unusual.
      for example I add sequence file temp_0101.png~temp_9999.png,
      [0000-0100] automatically increase[0000-9999] ,but {0000-0100} not increase.
      How do I change {} to [] without ctrl +H.
      there is so much deficent secuence files.
        • 1. Re: why sequence name is difference. _[9999]or{9999}
          KoMaruyama Adobe Community Professional
          The curly brackets { } represent a selected range sequence.
          Not unusual.
          Sometimes people will inefficiently select the WHOLE range of frames in a sequence when they don't need to.
          A sequence range is good when you want to import a fraction of a sequence. i.e.  temp_{0025-0098} instead of 0000-1000
          You do it the way I normally do:
          Select ONE frame in the sequence, choose "Sequence" and let Ae bring in the rest of the temp_####  files
          This results in regular brackets [ ]
          If you change the duration of your sequence, After Effects will reflect the change of the entire sequence.
          You can't replace those sequence ranges { } automatically when you add frames to your source sequence.  After Effects thinks you want ONLY those frames that were selected when they were imported.  'replace footage' time.
          I think you are doing it correctly. [ ]
