1. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
Stormy3000 Feb 11, 2015 8:26 AM (in response to Stormy3000)Ok I see we can't post weblink... handy...
The website I referred to that has achieved this is Kasra Design.
You don't need to look at it to help, just point in the right direction to stop an individual object being responsive.
2. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
Allison@HavasLynx May 19, 2015 8:29 AM (in response to Stormy3000)Hi,
Did you manage to acheve what you wanted?
I have a project which has to resize with the browser but I need the logo symbol on the main stage needs to remain same size and fixed position. I have tried a few things:
css(position: "fixed")
Max width
...but nothing seems to work
This post is marked as answered but there doesn't seem to be an answer to this problem.
Any advice greatly appreciated.
3. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
TomGreen May 20, 2015 1:44 PM (in response to Allison@HavasLynx)Have you turned off the Responsive Scaling option for the selected content on the Animate stage?
4. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
Allison@HavasLynx May 21, 2015 1:57 AM (in response to TomGreen)Hi Tom
I can't see an option for turning off responsive scaling on an individual item, only for the main stage.
Can you tell me how to do this please?
Or do I have to turn off responsive scaling in the Properties panel and then individually apply it to every item that needs to scale responsively using the layout presets?
5. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
TomGreen May 22, 2015 8:29 AM (in response to Allison@HavasLynx)You need to turn it off, in the Properties panel, for each non responsive element on the stage.
6. Re: Is there a way to prevent all objects being responsive in a responsive project? (Max W doesn't do anything?)
Allison@HavasLynx May 28, 2015 9:02 AM (in response to TomGreen)Hi Tom,
I still can't see where you turn off responsive scaling for an element
There is only an option for this on the Stage itself.
When I select an object there is nothing mentioning responsive scaling. There is a button which when clicked brings up Layout Preset, but I tried the 'Static Background image' becuse the description seemed to be what I wanted but the symbol still scales.
I am using 2014.1.1
