0 Replies Latest reply on Feb 11, 2015 3:04 AM by Stamm
    Linebreak in Indesign xsl?
    Stamm Level 1
      Hey guys,
      I have a little question about xsl. I tried to solve it myself, but I can't get it done.
      My xsl looks like this:
      <?xml version="1.0" encoding="UTF-8" ?>
      <xsl:transform xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="2.0"
      xmlns:ex="example">
          <xsl:output method="xml" omit-xml-declaration="yes" encoding="UTF-8" indent="yes" />
          <xsl:template match="@*|node()">
              <xsl:copy>
                  <xsl:apply-templates select="@*|node()"/>
              </xsl:copy>
          </xsl:template>
          <xsl:template match="*[local-name() = 'table']"/>
          <xsl:template match="*[local-name() = 'text']">
              <xsl:copy>
                  <xsl:attribute name="value">
                      <xsl:apply-templates/>
                  </xsl:attribute>
              </xsl:copy>
          </xsl:template>
          <xsl:template match="*[local-name() = 'b' or local-name() = 'i']">
              <xsl:value-of select="concat('[',local-name(),']')"/>
              <xsl:value-of select="concat('[/',local-name(),']')"/>
          </xsl:template>
          <xsl:template match="@value">
                   <xsl:value-of select="translate(.,'&#xd;','&#xa;')"/>
               </xsl:attribute>
          </xsl:template>
          <xsl:template match="@href"/>
      </xsl:transform>
      What I found out, is that I could use something like this:
      <xsl:if test="not(position()=last())">
          <xsl:text>&#xA;</xsl:text>
      </xsl:if>
      But I don't know how to combine it with my xsl. I tried to just put it in the "<xsl:attribute name="value">" xsl:copy part. It inserts a linebreak, but at the wrong place. Also I cant put it inside of "xsl:apply-templates".
      Would someone be so kind to tell me, where I have to add this code?
      A xml example(how it looks originally, without any transforms):
      <text>This is some text and here
      is a linebreak</text>
      Should look like:
      <text value="This is some text and here&#xA;is a linebreak"/>
      Currently looks like:
      is a linebreak"/>
      Thank you in advance!
