3 Replies Latest reply on Feb 16, 2015 9:12 AM by elim19034290
    Can't install photoshop cs5 on Windows 7 laptop
    elim19034290
      Hello, I was attempting to install Photoshop cs5 on my Windows 7 laptop and every time I attempt to install it, the installer stops and pulls up a message saying, "Installer failed to initialize." so I've tried turning off UAC, running as administrator, using the hidden admin feature, and turning off all services, all to no avail. There are no errors in the installer logs at all, nor are there any failures. I require assistance.
        • 1. Re: Can't install photoshop cs5 on Windows 7 laptop
          GautamBahl Adobe Employee
          Hi Eli,
          Please navigate to the location C:\Users\Username\AppData\Local\Temp and look for the amt3.log file.
          Please post the log so that i can help you out.
          Thank you for posting on Adobe Forums.
          • 2. Re: Can't install photoshop cs5 on Windows 7 laptop
            elim19034290 Level 1
            2015-01-13 00:33:25 [15844]  AMT: START SESSION, library version 3.0.0.64,3.0
            2015-01-13 00:33:25 [15844]  AMT: Initializing C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\
            2015-01-13 00:33:25 [15844]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
            2015-01-13 00:33:25 [15844]  AMT: Virtualization Turned off
            2015-01-13 00:33:25 [15844]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-13 00:33:25 [15844]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-13 00:33:25 [15844]  PCDService: PCD Service in threaded mode
            2015-01-13 00:33:25 [15844]  performance: AMTPreObtainProductLicense took 100.920700 ms
            2015-01-13 00:33:25 [15844]  PCD thread: PCD thread started
            2015-01-13 00:33:26 [15844]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-13 00:33:26 [15844]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-13 00:33:26 [15844]  AMT: App Product Locale [0] = en_US
            2015-01-13 00:33:26 [15844]  config: Loading configuration for C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\application.xml
            2015-01-13 00:33:26 [15844]  config: Found payload code {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-13 00:33:26 [15844]  PCDService: found driver code {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:26 [15844]  config: config: Host app was installed, using installed license configuration.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [FLMap] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-13 00:33:26 [15844]  config: Setting current license to the driver at startup because no mapping was found.
            2015-01-13 00:33:26 [15844]  config: Setting current license to Photoshop-CS5-Win-GM [ALL]
            2015-01-13 00:33:26 [15844]  config: payload code: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-13 00:33:26 [15844]  config: driver payload code: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:26 [15844]  config: driver licensing code: Photoshop-CS5-Win-GM
            2015-01-13 00:33:26 [15844]  config: current licensing code: Photoshop-CS5-Win-GM
            2015-01-13 00:33:26 [15844]  config: current locale code: ALL
            2015-01-13 00:33:26 [15844]  config: Done loading configuration
            2015-01-13 00:33:26 [15844]  AMT: Locale from PCD [0] = en_US
            2015-01-13 00:33:26 [15844]  AMT: Reordered Installed App Product Locale [0] = en_US
            2015-01-13 00:33:26 [15844]  config: Setting insalled locales
            2015-01-13 00:33:26 [15844]  config: Changing locale to "en_US" because old locale "" is not in the new list of installed languages
            2015-01-13 00:33:26 [15844]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-13 00:33:26 [15844]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-13 00:33:26 [15844]  AMT: config: Finding license info for payload: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:26 [15844]  AMT: config: PayloadCode: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-13 00:33:26 [15844]  AMT: config: Driver PayloadCode: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:26 [15844]  AMT: config: Installed LicensingCode: Photoshop-CS5-Win-GM
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [BridgeTalkCode] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [EULA] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [Registration] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [Registration] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [SuiteFeatureCount] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-13 00:33:26 [15844]  AMT: Application can be serialized (sif file found).
            2015-01-13 00:33:26 [15844]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-13 00:33:26 [15844]  AMT: Subsequent launch (serial [92628834335913950388]).
            2015-01-13 00:33:26 [15844]  AMT: Application state initialized.  Obtaining Product License.
            2015-01-13 00:33:26 [15844]  AMT: Obtaining client features from cache.
            2015-01-13 00:33:26 [15844]  AMT: Obtaining client product info from cache.
            2015-01-13 00:33:26 [15844]  AMT: Running in PROV_APP
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [EULADelay] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:26 [15844]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:26 [15844]  config: Using default media policy RET
            2015-01-13 00:33:26 [15844]  uiswitch: EULA has already been accepted.
            2015-01-13 00:33:26 [15844]  AMT: This is a subsequent launch. Deferring services.
            2015-01-13 00:33:26 [15844]  performance: AMTObtainProductLicense took 228.702499 ms
            2015-01-13 00:33:48 [15844]  AMT: Pre-Validating Product License.
            2015-01-13 00:33:48 [15844]  AMT: Services not yet loaded in this session.
            2015-01-13 00:33:48 [15844]  AMT: Loading services in background to get ready for Validate call.
            2015-01-13 00:33:48 [15844]  AMT: Spawning background thread to load services.
            2015-01-13 00:33:48 [15844]  performance: AMTPreValidateProductLicense took 10.070942 ms
            2015-01-13 00:33:48 [15844]  AMT: Starting work on prevalidate thread.
            2015-01-13 00:33:48 [15844]  AMT: AMT: PreValidating Product License.
            2015-01-13 00:33:48 [15844]  AMT: Launch Workflow not yet done in this session.
            2015-01-13 00:33:48 [15844]  AMT: Starting Background Subsequent Launch Workflow
            2015-01-13 00:33:48 [15844]  AMT: Starting ALM workflow.
            2015-01-13 00:33:48 [15844]  AMT: Initializing ALM for serialized activation.
            2015-01-13 00:33:48 [15844]  ALMService: Initializing as licensed app
            2015-01-13 00:33:48 [15844]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
            2015-01-13 00:33:48 [15844]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
            2015-01-13 00:33:48 [15844]  SLCoreService: Service construction took 0.1 ms and succeed.
            2015-01-13 00:33:48 [15844]  ALM: _info_: LEID passed Photoshop-CS5-Win-GM is used to configure SLCore = 0
            2015-01-13 00:33:48 [15844]  ALM: _info_: Host app is Licensable App
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [Photoshop-CS5-Win-GM{|}6] in hive [SSC-CS5-LE-Dominance] in master.
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID Photoshop-CS5-Win-GM with AMT Path C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID DesignSuiteStandard-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuiteStandard-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID WebSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\WebSuitePremium-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuitePremium-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID VideoSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\VideoSuitePremium-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID MasterCollection-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\MasterCollection-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found LEID ELearningSuite-ES2-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\ELearningSuite-ES2-Win-GM
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:48 [15844]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:48 [15844]  config: Using default media policy RET
            2015-01-13 00:33:48 [15844]  ALM: _info_: MediaTagPolicy is RET
            2015-01-13 00:33:48 [15844]  ALM: _info_: Canonical LEID is Photoshop-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Driver LEID is Photoshop-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [926287090233530048226122] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-13 00:33:48 [15844]  SLCoreService: Reading product config [C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\SLConfig.xml]
            2015-01-13 00:33:48 [15844]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
            2015-01-13 00:33:48 [15844]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
            2015-01-13 00:33:48 [15844]  ALM: _info_: Set Running Locale to en_US
            2015-01-13 00:33:48 [15844]  ALM: _time_: (func: ALM_Initialize, duration: 0.062 sec)
            2015-01-13 00:33:48 [15844]  AMT: Performing ALM silent license verification.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [EncryptedSerial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [Serial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-13 00:33:48 [15844]  config: No pre-serial number found in {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-13 00:33:48 [15844]  config: No en_US provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-13 00:33:48 [15844]  config: No ALL provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-13 00:33:48 [15844]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_US
            2015-01-13 00:33:48 [15844]  ALM: _info_: Searching license for locale en_US ...
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [926288343359139503880822] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-13 00:33:48 [15844]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_US
            2015-01-13 00:33:48 [15844]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
            2015-01-13 00:33:48 [15844]  ALM: _info_: Found existing serialization under LEID Photoshop-CS5-Win-GM, the serial number locale is en_US
            2015-01-13 00:33:48 [15844]  ALM: _info_: This is the running locale, stop the search
            2015-01-13 00:33:48 [15844]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-13 00:33:48 [15844]  SLCoreService: Syncing to license store...
            2015-01-13 00:33:48 [15844]  SLCoreService: Found server mkey.
            2015-01-13 00:33:48 [15844]  SLCoreService: Loading license references...
            2015-01-13 00:33:48 [15844]  SLCoreService: Found 2 license file(s)
            2015-01-13 00:33:48 [15844]  SLCoreService: Parsing license file [194952429.lic] succeed.
            2015-01-13 00:33:48 [15844]  SLCoreService: Parsing license file [219666445.lic] succeed.
            2015-01-13 00:33:48 [15844]  SLCoreService: License store synchronization took 87.0 ms and succeed.
            2015-01-13 00:33:48 [15844]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [PDApp_WF] in hive [Photoshop-CS5-Win-GM] in cache.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature ALM_PhotoshopCS5XSGM_12.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Photoshop_12.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
            2015-01-13 00:33:48 [15844]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [ALM_Info_S1] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [ADOBEID] in hive [926288343359139503880822] in cache.
            2015-01-13 00:33:48 [15844]  ALM: _info_: Performing Block Check
            2015-01-13 00:33:48 [15844]  ALM: _info_: Block Check ByPassed
            2015-01-13 00:33:48 [15844]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.125 sec)
            2015-01-13 00:33:48 [15844]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
            2015-01-13 00:33:48 [15844]  AMT: License check shows serialized product is already activated.
            2015-01-13 00:33:48 [15844]  ALM: _info_: Entered ALM_NeedANAG
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [ClaimStatus] in hive [926288343359139503880822] in cache.
            2015-01-13 00:33:48 [15844]  ALM: _info_: Exiting ALM_NeedANAG
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:48 [15844]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:48 [15844]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
            2015-01-13 00:33:48 [15844]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-13 00:33:48 [15844]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-13 00:33:48 [15844]  AUMService: IsUpdaterEnabled call
            2015-01-13 00:33:49 [15844]  AUMService: IsUpdaterEnabled call succeeded
            2015-01-13 00:33:49 [15844]  ALM: _info_: Deactivation menu is enabled
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [ADOBEID] in hive [926288343359139503880822] in cache.
            2015-01-13 00:33:49 [15844]  AMT: Completed Launch Workflow successfully.
            2015-01-13 00:33:49 [15844]  AMT: Calling AUM API to create scheduler entry to be used by updater.
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-13 00:33:49 [15844]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
            2015-01-13 00:33:49 [15844]  AUMService: Get LEID xml call
            2015-01-13 00:33:49 [15844]  AUMService: Get LEID XML call succeeded
            2015-01-13 00:33:49 [15844]  AMT: AUM GetLEID called with status =0.
            2015-01-13 00:33:49 [15844]  AMT: Checking client features against cache.
            2015-01-13 00:33:49 [15844]  AMT: Feature AMT_ALLOW_DRAGDROP_INSTALL 3.0 is unlicensed (was unlicensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature AMT_REQUEST_NO_TAMPERPROOFING 3.3 is unlicensed (was unlicensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature Photoshop_Premium 12.0 is licensed (was licensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature Photoshop_Base 12.0 is licensed (was licensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature Bridge_Base 4.0 is licensed (was licensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature Bridge_CameraRaw 4.0 is licensed (was licensed).
            2015-01-13 00:33:49 [15844]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
            2015-01-13 00:33:49 [15844]  AMT: Validating client product info against cache.
            2015-01-13 00:33:49 [15844]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-13 00:33:49 [15844]  AMT: Starting Data Collection for SWTag_Init()
            2015-01-13 00:33:49 [15844]  AMT: DoISOTagging() productCanonicalLEID = Photoshop-CS5-Win-GM;outMappedLEID =  Photoshop-CS5-Win-GM, unused = Photoshop-CS5-Win-GM
            2015-01-13 00:33:49 [15844]  AMT: DoISOTagging() productPayloadCode = {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84};driverPayloadCode =  {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-13 00:33:49 [15844]  AMT: SWTag_Init() Tags Arguments Adobe Photoshop CS5 Extended; Photoshop-CS5-Win-GM; en_US
            2015-01-13 00:33:49 [15844]  AMT: DoISOTagging() License Status = activated
            2015-01-13 00:33:49 [15844]  AMT: DoISOTagging() Tags 926288343359139503880822; 12.0; RETAIL
            2015-01-13 00:33:49 [15844]  AMT: DoISOTagging() Product Version 12; 0
            2015-01-13 00:33:49 [15844]  AMT: AMT: Product License PreValidated.
            2015-01-13 00:33:49 [15844]  AMT: Prevalidate indicates license is good and no UI required.
            2015-01-13 00:33:49 [15844]  performance: PreValidate thread took 338.171326 ms
            2015-01-13 00:33:49 [15844]  AMT: PlugPlug : AdobeId has not been created
            2015-01-13 00:33:49 [15844]  AMT: PlugPlug : Can Go Online returned as true
            2015-01-13 00:33:49 [15844]  performance: AMTPlugPlugRequest took 50.706043 ms
            2015-01-13 00:33:49 [15844]  performance: AMTPlugPlugRequest took 2.886364 ms
            2015-01-13 00:33:49 [15844]  performance: AMTPlugPlugRequest took 3.112712 ms
            2015-01-13 00:33:49 [15844]  performance: AMTPlugPlugRequest took 2.741173 ms
            2015-01-13 00:33:49 [15844]  performance: AMTPlugPlugRequest took 2.755555 ms
            2015-01-18 21:41:15 [24952]  AMT: START SESSION, library version 3.0.0.64,3.0
            2015-01-18 21:41:15 [24952]  AMT: Initializing C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\
            2015-01-18 21:41:15 [24952]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
            2015-01-18 21:41:15 [24952]  AMT: Virtualization Turned off
            2015-01-18 21:41:15 [24952]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-18 21:41:15 [24952]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-18 21:41:15 [24952]  PCDService: PCD Service in threaded mode
            2015-01-18 21:41:15 [24952]  performance: AMTPreObtainProductLicense took 59.506001 ms
            2015-01-18 21:41:15 [24952]  PCD thread: PCD thread started
            2015-01-18 21:41:15 [24952]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-18 21:41:15 [24952]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-18 21:41:15 [24952]  AMT: App Product Locale [0] = en_US
            2015-01-18 21:41:15 [24952]  config: Loading configuration for C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\application.xml
            2015-01-18 21:41:15 [24952]  config: Found payload code {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-18 21:41:15 [24952]  PCDService: found driver code {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:15 [24952]  config: config: Host app was installed, using installed license configuration.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [FLMap] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-18 21:41:15 [24952]  config: Setting current license to the driver at startup because no mapping was found.
            2015-01-18 21:41:15 [24952]  config: Setting current license to Photoshop-CS5-Win-GM [ALL]
            2015-01-18 21:41:15 [24952]  config: payload code: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-18 21:41:15 [24952]  config: driver payload code: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:15 [24952]  config: driver licensing code: Photoshop-CS5-Win-GM
            2015-01-18 21:41:15 [24952]  config: current licensing code: Photoshop-CS5-Win-GM
            2015-01-18 21:41:15 [24952]  config: current locale code: ALL
            2015-01-18 21:41:15 [24952]  config: Done loading configuration
            2015-01-18 21:41:15 [24952]  AMT: Locale from PCD [0] = en_US
            2015-01-18 21:41:15 [24952]  AMT: Reordered Installed App Product Locale [0] = en_US
            2015-01-18 21:41:15 [24952]  config: Setting insalled locales
            2015-01-18 21:41:15 [24952]  config: Changing locale to "en_US" because old locale "" is not in the new list of installed languages
            2015-01-18 21:41:15 [24952]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-18 21:41:15 [24952]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-18 21:41:15 [24952]  AMT: config: Finding license info for payload: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:15 [24952]  AMT: config: PayloadCode: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-18 21:41:15 [24952]  AMT: config: Driver PayloadCode: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:15 [24952]  AMT: config: Installed LicensingCode: Photoshop-CS5-Win-GM
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [BridgeTalkCode] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [EULA] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [Registration] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [Registration] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [SuiteFeatureCount] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-18 21:41:15 [24952]  AMT: Application can be serialized (sif file found).
            2015-01-18 21:41:15 [24952]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-18 21:41:15 [24952]  AMT: Subsequent launch (serial [92628834335913950388]).
            2015-01-18 21:41:15 [24952]  AMT: Application state initialized.  Obtaining Product License.
            2015-01-18 21:41:15 [24952]  AMT: Obtaining client features from cache.
            2015-01-18 21:41:15 [24952]  AMT: Obtaining client product info from cache.
            2015-01-18 21:41:15 [24952]  AMT: Running in PROV_APP
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [EULADelay] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:15 [24952]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:15 [24952]  config: Using default media policy RET
            2015-01-18 21:41:15 [24952]  uiswitch: EULA has already been accepted.
            2015-01-18 21:41:15 [24952]  AMT: This is a subsequent launch. Deferring services.
            2015-01-18 21:41:15 [24952]  performance: AMTObtainProductLicense took 204.568893 ms
            2015-01-18 21:41:42 [24952]  AMT: Pre-Validating Product License.
            2015-01-18 21:41:42 [24952]  AMT: Services not yet loaded in this session.
            2015-01-18 21:41:42 [24952]  AMT: Loading services in background to get ready for Validate call.
            2015-01-18 21:41:42 [24952]  AMT: Spawning background thread to load services.
            2015-01-18 21:41:42 [24952]  performance: AMTPreValidateProductLicense took 0.469805 ms
            2015-01-18 21:41:42 [24952]  AMT: Starting work on prevalidate thread.
            2015-01-18 21:41:42 [24952]  AMT: AMT: PreValidating Product License.
            2015-01-18 21:41:42 [24952]  AMT: Launch Workflow not yet done in this session.
            2015-01-18 21:41:42 [24952]  AMT: Starting Background Subsequent Launch Workflow
            2015-01-18 21:41:42 [24952]  AMT: Starting ALM workflow.
            2015-01-18 21:41:42 [24952]  AMT: Initializing ALM for serialized activation.
            2015-01-18 21:41:42 [24952]  ALMService: Initializing as licensed app
            2015-01-18 21:41:42 [24952]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
            2015-01-18 21:41:42 [24952]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
            2015-01-18 21:41:42 [24952]  SLCoreService: Service construction took 0.1 ms and succeed.
            2015-01-18 21:41:42 [24952]  ALM: _info_: LEID passed Photoshop-CS5-Win-GM is used to configure SLCore = 0
            2015-01-18 21:41:42 [24952]  ALM: _info_: Host app is Licensable App
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [Photoshop-CS5-Win-GM{|}6] in hive [SSC-CS5-LE-Dominance] in master.
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID Photoshop-CS5-Win-GM with AMT Path C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID DesignSuiteStandard-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuiteStandard-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID WebSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\WebSuitePremium-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuitePremium-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID VideoSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\VideoSuitePremium-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID MasterCollection-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\MasterCollection-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found LEID ELearningSuite-ES2-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\ELearningSuite-ES2-Win-GM
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:42 [24952]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:42 [24952]  config: Using default media policy RET
            2015-01-18 21:41:42 [24952]  ALM: _info_: MediaTagPolicy is RET
            2015-01-18 21:41:42 [24952]  ALM: _info_: Canonical LEID is Photoshop-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Driver LEID is Photoshop-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [926287090233530048226122] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-18 21:41:42 [24952]  SLCoreService: Reading product config [C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\SLConfig.xml]
            2015-01-18 21:41:42 [24952]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
            2015-01-18 21:41:42 [24952]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
            2015-01-18 21:41:42 [24952]  ALM: _info_: Set Running Locale to en_US
            2015-01-18 21:41:42 [24952]  ALM: _time_: (func: ALM_Initialize, duration: 0.078 sec)
            2015-01-18 21:41:42 [24952]  AMT: Performing ALM silent license verification.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [EncryptedSerial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [Serial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-18 21:41:42 [24952]  config: No pre-serial number found in {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-18 21:41:42 [24952]  config: No en_US provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-18 21:41:42 [24952]  config: No ALL provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_US
            2015-01-18 21:41:42 [24952]  ALM: _info_: Searching license for locale en_US ...
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [926288343359139503880822] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-18 21:41:42 [24952]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_US
            2015-01-18 21:41:42 [24952]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
            2015-01-18 21:41:42 [24952]  ALM: _info_: Found existing serialization under LEID Photoshop-CS5-Win-GM, the serial number locale is en_US
            2015-01-18 21:41:42 [24952]  ALM: _info_: This is the running locale, stop the search
            2015-01-18 21:41:42 [24952]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-18 21:41:42 [24952]  SLCoreService: Syncing to license store...
            2015-01-18 21:41:42 [24952]  SLCoreService: Found server mkey.
            2015-01-18 21:41:42 [24952]  SLCoreService: Loading license references...
            2015-01-18 21:41:42 [24952]  SLCoreService: Found 2 license file(s)
            2015-01-18 21:41:42 [24952]  SLCoreService: Parsing license file [194952429.lic] succeed.
            2015-01-18 21:41:42 [24952]  SLCoreService: Parsing license file [219666445.lic] succeed.
            2015-01-18 21:41:42 [24952]  SLCoreService: License store synchronization took 467.1 ms and succeed.
            2015-01-18 21:41:42 [24952]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [PDApp_WF] in hive [Photoshop-CS5-Win-GM] in cache.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature ALM_PhotoshopCS5XSGM_12.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Photoshop_12.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
            2015-01-18 21:41:42 [24952]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [ALM_Info_S1] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [ADOBEID] in hive [926288343359139503880822] in cache.
            2015-01-18 21:41:42 [24952]  ALM: _info_: Performing Block Check
            2015-01-18 21:41:42 [24952]  ALM: _info_: Block Check ByPassed
            2015-01-18 21:41:42 [24952]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.499 sec)
            2015-01-18 21:41:42 [24952]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
            2015-01-18 21:41:42 [24952]  AMT: License check shows serialized product is already activated.
            2015-01-18 21:41:42 [24952]  ALM: _info_: Entered ALM_NeedANAG
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [ClaimStatus] in hive [926288343359139503880822] in cache.
            2015-01-18 21:41:42 [24952]  ALM: _info_: Exiting ALM_NeedANAG
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-18 21:41:42 [24952]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
            2015-01-18 21:41:42 [24952]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-18 21:41:42 [24952]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-18 21:41:42 [24952]  AUMService: IsUpdaterEnabled call
            2015-01-18 21:41:42 [24952]  AUMService: IsUpdaterEnabled call succeeded
            2015-01-18 21:41:42 [24952]  ALM: _info_: Deactivation menu is enabled
            2015-01-18 21:41:42 [24952]  AMT: Completed Launch Workflow successfully.
            2015-01-18 21:41:42 [24952]  AMT: Calling AUM API to create scheduler entry to be used by updater.
            2015-01-18 21:41:42 [24952]  AUMService: Get LEID xml call
            2015-01-18 21:41:42 [24952]  AUMService: Get LEID XML call succeeded
            2015-01-18 21:41:42 [24952]  AMT: AUM GetLEID called with status =0.
            2015-01-18 21:41:42 [24952]  AMT: Checking client features against cache.
            2015-01-18 21:41:42 [24952]  AMT: Feature AMT_ALLOW_DRAGDROP_INSTALL 3.0 is unlicensed (was unlicensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature AMT_REQUEST_NO_TAMPERPROOFING 3.3 is unlicensed (was unlicensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature Photoshop_Premium 12.0 is licensed (was licensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature Photoshop_Base 12.0 is licensed (was licensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature Bridge_Base 4.0 is licensed (was licensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature Bridge_CameraRaw 4.0 is licensed (was licensed).
            2015-01-18 21:41:42 [24952]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
            2015-01-18 21:41:42 [24952]  AMT: Validating client product info against cache.
            2015-01-18 21:41:42 [24952]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-18 21:41:42 [24952]  AMT: Starting Data Collection for SWTag_Init()
            2015-01-18 21:41:42 [24952]  AMT: DoISOTagging() productCanonicalLEID = Photoshop-CS5-Win-GM;outMappedLEID =  Photoshop-CS5-Win-GM, unused = Photoshop-CS5-Win-GM
            2015-01-18 21:41:42 [24952]  AMT: DoISOTagging() productPayloadCode = {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84};driverPayloadCode =  {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-18 21:41:42 [24952]  AMT: SWTag_Init() Tags Arguments Adobe Photoshop CS5 Extended; Photoshop-CS5-Win-GM; en_US
            2015-01-18 21:41:42 [24952]  AMT: DoISOTagging() License Status = activated
            2015-01-18 21:41:42 [24952]  AMT: DoISOTagging() Tags 926288343359139503880822; 12.0; RETAIL
            2015-01-18 21:41:42 [24952]  AMT: DoISOTagging() Product Version 12; 0
            2015-01-18 21:41:42 [24952]  AMT: AMT: Product License PreValidated.
            2015-01-18 21:41:42 [24952]  AMT: Prevalidate indicates license is good and no UI required.
            2015-01-18 21:41:42 [24952]  performance: PreValidate thread took 786.569214 ms
            2015-01-18 21:41:42 [24952]  AMT: PlugPlug : AdobeId has not been created
            2015-01-18 21:41:42 [24952]  AMT: PlugPlug : Can Go Online returned as true
            2015-01-18 21:41:43 [24952]  performance: AMTPlugPlugRequest took 59.772064 ms
            2015-01-18 21:41:43 [24952]  performance: AMTPlugPlugRequest took 3.952251 ms
            2015-01-18 21:41:43 [24952]  performance: AMTPlugPlugRequest took 3.212616 ms
            2015-01-18 21:41:43 [24952]  performance: AMTPlugPlugRequest took 3.690640 ms
            2015-01-18 21:41:43 [24952]  performance: AMTPlugPlugRequest took 2.644878 ms
            2015-01-19 14:22:04 [660]  AMT: START SESSION, library version 3.0.0.64,3.0
            2015-01-19 14:22:04 [660]  AMT: Initializing C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\
            2015-01-19 14:22:04 [660]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
            2015-01-19 14:22:04 [660]  AMT: Virtualization Turned off
            2015-01-19 14:22:04 [660]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-19 14:22:04 [660]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\adobe_caps.dll
            2015-01-19 14:22:04 [660]  PCDService: PCD Service in threaded mode
            2015-01-19 14:22:04 [660]  performance: AMTPreObtainProductLicense took 42.214592 ms
            2015-01-19 14:22:04 [660]  PCD thread: PCD thread started
            2015-01-19 14:22:04 [660]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-19 14:22:04 [660]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Adobe_OOBE_Launcher.dll
            2015-01-19 14:22:04 [660]  AMT: App Product Locale [0] = en_US
            2015-01-19 14:22:04 [660]  config: Loading configuration for C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\application.xml
            2015-01-19 14:22:04 [660]  config: Found payload code {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-19 14:22:04 [660]  PCDService: found driver code {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:04 [660]  config: config: Host app was installed, using installed license configuration.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [FLMap] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-19 14:22:04 [660]  config: Setting current license to the driver at startup because no mapping was found.
            2015-01-19 14:22:04 [660]  config: Setting current license to Photoshop-CS5-Win-GM [ALL]
            2015-01-19 14:22:04 [660]  config: payload code: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-19 14:22:04 [660]  config: driver payload code: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:04 [660]  config: driver licensing code: Photoshop-CS5-Win-GM
            2015-01-19 14:22:04 [660]  config: current licensing code: Photoshop-CS5-Win-GM
            2015-01-19 14:22:04 [660]  config: current locale code: ALL
            2015-01-19 14:22:04 [660]  config: Done loading configuration
            2015-01-19 14:22:04 [660]  AMT: Locale from PCD [0] = en_US
            2015-01-19 14:22:04 [660]  AMT: Reordered Installed App Product Locale [0] = en_US
            2015-01-19 14:22:04 [660]  config: Setting insalled locales
            2015-01-19 14:22:04 [660]  config: Changing locale to "en_US" because old locale "" is not in the new list of installed languages
            2015-01-19 14:22:04 [660]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-19 14:22:04 [660]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\asneu.dll
            2015-01-19 14:22:04 [660]  AMT: config: Finding license info for payload: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:04 [660]  AMT: config: PayloadCode: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
            2015-01-19 14:22:04 [660]  AMT: config: Driver PayloadCode: {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:04 [660]  AMT: config: Installed LicensingCode: Photoshop-CS5-Win-GM
            2015-01-19 14:22:04 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [BridgeTalkCode] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [EULA] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [Registration] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [Registration] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [SuiteFeatureCount] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-19 14:22:04 [660]  AMT: Application can be serialized (sif file found).
            2015-01-19 14:22:04 [660]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-19 14:22:04 [660]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-19 14:22:04 [660]  AMT: Subsequent launch (serial [92628834335913950388]).
            2015-01-19 14:22:04 [660]  AMT: Application state initialized.  Obtaining Product License.
            2015-01-19 14:22:04 [660]  AMT: Obtaining client features from cache.
            2015-01-19 14:22:04 [660]  AMT: Obtaining client product info from cache.
            2015-01-19 14:22:04 [660]  AMT: Running in PROV_APP
            2015-01-19 14:22:04 [660]  PCDService: No value for key [EULADelay] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:04 [660]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:04 [660]  config: Using default media policy RET
            2015-01-19 14:22:04 [660]  uiswitch: EULA has already been accepted.
            2015-01-19 14:22:04 [660]  AMT: This is a subsequent launch. Deferring services.
            2015-01-19 14:22:04 [660]  performance: AMTObtainProductLicense took 181.825348 ms
            2015-01-19 14:22:47 [660]  AMT: Pre-Validating Product License.
            2015-01-19 14:22:47 [660]  AMT: Services not yet loaded in this session.
            2015-01-19 14:22:47 [660]  AMT: Loading services in background to get ready for Validate call.
            2015-01-19 14:22:47 [660]  AMT: Spawning background thread to load services.
            2015-01-19 14:22:47 [660]  performance: AMTPreValidateProductLicense took 0.665333 ms
            2015-01-19 14:22:47 [660]  AMT: Starting work on prevalidate thread.
            2015-01-19 14:22:47 [660]  AMT: AMT: PreValidating Product License.
            2015-01-19 14:22:47 [660]  AMT: Launch Workflow not yet done in this session.
            2015-01-19 14:22:47 [660]  AMT: Starting Background Subsequent Launch Workflow
            2015-01-19 14:22:47 [660]  AMT: Starting ALM workflow.
            2015-01-19 14:22:47 [660]  AMT: Initializing ALM for serialized activation.
            2015-01-19 14:22:47 [660]  ALMService: Initializing as licensed app
            2015-01-19 14:22:47 [660]  ALM: _info_: Start ALM 3.2 Release (build 3.2.64.0)
            2015-01-19 14:22:47 [660]  SLCoreService: Starting up SLCore 1.0 Release (build 1.0.13.199023).
            2015-01-19 14:22:47 [660]  SLCoreService: Service construction took 0.1 ms and succeed.
            2015-01-19 14:22:47 [660]  ALM: _info_: LEID passed Photoshop-CS5-Win-GM is used to configure SLCore = 0
            2015-01-19 14:22:47 [660]  ALM: _info_: Host app is Licensable App
            2015-01-19 14:22:47 [660]  PCDService: No value for key [Photoshop-CS5-Win-GM{|}6] in hive [SSC-CS5-LE-Dominance] in master.
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID Photoshop-CS5-Win-GM with AMT Path C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID DesignSuiteStandard-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuiteStandard-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID WebSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\WebSuitePremium-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID DesignSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\DesignSuitePremium-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID VideoSuitePremium-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\VideoSuitePremium-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID MasterCollection-CS5-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\MasterCollection-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Found LEID ELearningSuite-ES2-Win-GM with AMT Path C:\Program Files (x86)\Common Files\Adobe\ssc\ELearningSuite-ES2-Win-GM
            2015-01-19 14:22:47 [660]  PCDService: No value for key [MediaTag] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:47 [660]  config: No media tag found for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:47 [660]  config: Using default media policy RET
            2015-01-19 14:22:47 [660]  ALM: _info_: MediaTagPolicy is RET
            2015-01-19 14:22:47 [660]  ALM: _info_: Canonical LEID is Photoshop-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Driver LEID is Photoshop-CS5-Win-GM
            2015-01-19 14:22:47 [660]  PCDService: No value for key [926287090233530048226122] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-19 14:22:47 [660]  SLCoreService: Reading product config [C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\AMT\SLConfig.xml]
            2015-01-19 14:22:47 [660]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for ALL
            2015-01-19 14:22:47 [660]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is not installed
            2015-01-19 14:22:47 [660]  ALM: _info_: Set Running Locale to en_US
            2015-01-19 14:22:47 [660]  ALM: _time_: (func: ALM_Initialize, duration: 0.109 sec)
            2015-01-19 14:22:47 [660]  AMT: Performing ALM silent license verification.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [EncryptedSerial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [Serial] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in cache.
            2015-01-19 14:22:47 [660]  config: No pre-serial number found in {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:47 [660]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-19 14:22:47 [660]  config: No en_US provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-19 14:22:47 [660]  PCDService: No value for key [PSN] in hive [Photoshop-CS5-Win-GM{|}ALL] in cache.
            2015-01-19 14:22:47 [660]  config: No ALL provisional serial number found in Photoshop-CS5-Win-GM
            2015-01-19 14:22:47 [660]  ALM: _info_: Validate license at Post-Chrome time, running locale is en_US
            2015-01-19 14:22:47 [660]  ALM: _info_: Searching license for locale en_US ...
            2015-01-19 14:22:47 [660]  PCDService: No value for key [926288343359139503880822] in hive [RejectedSNDomain_CS5] in cache.
            2015-01-19 14:22:47 [660]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Checking if lang pack is installed for en_US
            2015-01-19 14:22:47 [660]  ALM: _info_: alm::IsLangPackForLocaleInstalled - Lang pack is installed
            2015-01-19 14:22:47 [660]  ALM: _info_: Found existing serialization under LEID Photoshop-CS5-Win-GM, the serial number locale is en_US
            2015-01-19 14:22:47 [660]  ALM: _info_: This is the running locale, stop the search
            2015-01-19 14:22:47 [660]  config: Setting current license to Photoshop-CS5-Win-GM [en_US]
            2015-01-19 14:22:47 [660]  SLCoreService: Syncing to license store...
            2015-01-19 14:22:47 [660]  SLCoreService: Found server mkey.
            2015-01-19 14:22:47 [660]  SLCoreService: Loading license references...
            2015-01-19 14:22:47 [660]  SLCoreService: Found 2 license file(s)
            2015-01-19 14:22:47 [660]  SLCoreService: Parsing license file [194952429.lic] succeed.
            2015-01-19 14:22:47 [660]  SLCoreService: Parsing license file [219666445.lic] succeed.
            2015-01-19 14:22:47 [660]  SLCoreService: License store synchronization took 99.0 ms and succeed.
            2015-01-19 14:22:47 [660]  SLCoreService: Query license: type = 3, duration = permanent, remaining = permanent.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [PDApp_WF] in hive [Photoshop-CS5-Win-GM] in cache.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature ALM_PhotoshopCS5XSGM_12.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Bridge_Base_4.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Bridge_CameraRaw_4.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Bridge_MiniBridge_1.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature MobileCenter_Base_3.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Photoshop_12.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Photoshop_Base_12.0 is enabled.
            2015-01-19 14:22:47 [660]  SLCoreService: Feature Photoshop_Premium_12.0 is enabled.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [ALM_Info_S1] in hive [Photoshop-CS5-Win-GM{|}en_US] in cache.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [ADOBEID] in hive [926288343359139503880822] in cache.
            2015-01-19 14:22:47 [660]  ALM: _info_: Performing Block Check
            2015-01-19 14:22:47 [660]  ALM: _info_: Block Check ByPassed
            2015-01-19 14:22:47 [660]  ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.141 sec)
            2015-01-19 14:22:47 [660]  ALM: _info_: ALM_License_SilentValidate return license status: Valid And Activated
            2015-01-19 14:22:47 [660]  AMT: License check shows serialized product is already activated.
            2015-01-19 14:22:47 [660]  ALM: _info_: Entered ALM_NeedANAG
            2015-01-19 14:22:47 [660]  PCDService: No value for key [ClaimStatus] in hive [926288343359139503880822] in cache.
            2015-01-19 14:22:47 [660]  ALM: _info_: Exiting ALM_NeedANAG
            2015-01-19 14:22:47 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:47 [660]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
            2015-01-19 14:22:47 [660]  ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-19 14:22:47 [660]  ServiceLoader: Found library C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\updaternotifications.dll
            2015-01-19 14:22:47 [660]  AUMService: IsUpdaterEnabled call
            2015-01-19 14:22:47 [660]  AUMService: IsUpdaterEnabled call succeeded
            2015-01-19 14:22:47 [660]  ALM: _info_: Deactivation menu is enabled
            2015-01-19 14:22:47 [660]  AMT: Completed Launch Workflow successfully.
            2015-01-19 14:22:47 [660]  AMT: Calling AUM API to create scheduler entry to be used by updater.
            2015-01-19 14:22:47 [660]  AUMService: Get LEID xml call
            2015-01-19 14:22:47 [660]  AUMService: Get LEID XML call succeeded
            2015-01-19 14:22:47 [660]  AMT: AUM GetLEID called with status =0.
            2015-01-19 14:22:47 [660]  AMT: Checking client features against cache.
            2015-01-19 14:22:47 [660]  AMT: Feature AMT_ALLOW_DRAGDROP_INSTALL 3.0 is unlicensed (was unlicensed).
            2015-01-19 14:22:47 [660]  AMT: Feature AMT_REQUEST_NO_TAMPERPROOFING 3.3 is unlicensed (was unlicensed).
            2015-01-19 14:22:47 [660]  AMT: Feature Photoshop_Premium 12.0 is licensed (was licensed).
            2015-01-19 14:22:47 [660]  AMT: Feature Photoshop_Base 12.0 is licensed (was licensed).
            2015-01-19 14:22:47 [660]  AMT: Feature Bridge_Base 4.0 is licensed (was licensed).
            2015-01-19 14:22:47 [660]  AMT: Feature Bridge_CameraRaw 4.0 is licensed (was licensed).
            2015-01-19 14:22:47 [660]  AMT: Feature MobileCenter_Base 3.0 is licensed (was licensed).
            2015-01-19 14:22:47 [660]  AMT: Validating client product info against cache.
            2015-01-19 14:22:47 [660]  PCDService: No value for key [ExpirationDate] in hive [Photoshop-CS5-Win-GM] in master.
            2015-01-19 14:22:47 [660]  AMT: Starting Data Collection for SWTag_Init()
            2015-01-19 14:22:47 [660]  AMT: DoISOTagging() productCanonicalLEID = Photoshop-CS5-Win-GM;outMappedLEID =  Photoshop-CS5-Win-GM, unused = Photoshop-CS5-Win-GM
            2015-01-19 14:22:47 [660]  AMT: DoISOTagging() productPayloadCode = {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84};driverPayloadCode =  {15FEDA5F-141C-4127-8D7E-B962D1742728}
            2015-01-19 14:22:47 [660]  AMT: SWTag_Init() Tags Arguments Adobe Photoshop CS5 Extended; Photoshop-CS5-Win-GM; en_US
            2015-01-19 14:22:47 [660]  AMT: DoISOTagging() License Status = activated
            2015-01-19 14:22:47 [660]  AMT: DoISOTagging() Tags 926288343359139503880822; 12.0; RETAIL
            2015-01-19 14:22:47 [660]  AMT: DoISOTagging() Product Version 12; 0
            2015-01-19 14:22:47 [660]  AMT: AMT: Product License PreValidated.
            2015-01-19 14:22:47 [660]  AMT: Prevalidate indicates license is good and no UI required.
            2015-01-19 14:22:47 [660]  performance: PreValidate thread took 513.295532 ms
            2015-01-19 14:22:48 [660]  AMT: PlugPlug : AdobeId has not been created
            2015-01-19 14:22:48 [660]  AMT: PlugPlug : Can Go Online returned as true
            2015-01-19 14:22:48 [660]  performance: AMTPlugPlugRequest took 69.368614 ms
            2015-01-19 14:22:48 [660]  performance: AMTPlugPlugRequest took 3.469800 ms
            2015-01-19 14:22:48 [660]  performance: AMTPlugPlugRequest took 3.320503 ms
            2015-01-19 14:22:48 [660]  performance: AMTPlugPlugRequest took 4.026927 ms
            2015-01-19 14:22:48 [660]  performance: AMTPlugPlugRequest took 3.324269 ms
            2015-01-19 14:22:51 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:51 [660]  PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:51 [660]  PCDService: No value for key [Updates] in hive [{15FEDA5F-141C-4127-8D7E-B962D1742728}] in master.
            2015-01-19 14:22:51 [660]  PCDService: No value for key [Updates] in hive [{667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}] in master.
            2015-01-19 14:22:51 [660]  AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
            2015-01-19 14:22:51 [660]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call
            2015-01-19 14:22:51 [660]  AUMService: UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd call succeeded
            2015-01-19 14:22:51 [660]  AMT: AUM UpdaterNotificationsLaunchAAMNotifierOnQuitIfReqd called with status =0.
            2015-01-19 14:22:51 [660]  ALMService: Terminating
            2015-01-19 14:22:51 [660]  SLCoreService: Shutting down SLCore 1.0 Release (build 1.0.13.199023).
            2015-01-19 14:22:51 [660]  SLCoreService: Service destruction took 14.0 ms and succeed.
            2015-01-19 14:22:51 [660]  ALM: _info_: End ALM
            2015-01-19 14:22:51 [660]  performance: AMTReleaseProductLicense took 54.182373 ms
            2015-01-19 14:22:51 [660]  AMT: END SESSION.
            This?
