6 Replies Latest reply on Feb 12, 2015 8:10 AM by r_tist
    input and select...
    r_tist Level 1
      Wanted to alter source code so that it would be a dropdown pick list instead of a txt field. Where I'm unsure... does 'select name' replace 'input' in this case? Or does 'input' still need to be there even though not a field as such? Also, if it does need 'input-type="?what word attribute for pick list?"'
      With my alterations:
      <div class="formblock">
                                <label class="screen-reader-text">How did you hear about this?</label>
                                   <select name="howHeard" id="howHeard" value="<?php if(isset($_POST['howHeard']))  echo $_POST['howHeard'];?>" class="tick">
                                    <option value="volvo">Volvo</option>
                                    <option value="saab">Saab</option>
                                    <option value="mercedes">Mercedes</option>
                                    <option value="audi">Audi</option>
                                  </select>
                                  <?php if($howHeardError != '') { ?>
                                      <br /><span class="error"><?php echo $howHeardError;?></span>
                                  <?php } ?>
                              </div>
      Other field example that I sourced, which is set up correctly:
                                  <label class="screen-reader-text">Email</label>
                                  <input type="text" name="email" id="email" value="<?php if(isset($_POST['email']))  echo $_POST['email'];?>" class="txt requiredField email" placeholder="Email:" />
                                  <?php if($emailError != '') { ?>
                                      <br /><span class="error"><?php echo $emailError;?></span>
                                  <?php } ?>
                              </div>
      Thanks.
        • 1. Re: input and select...
          osgood_ Level 8
          r_tist wrote:
                                      </select>
                                      <?php } ?>
                                  </div>
                                      <?php } ?>
                                  </div>
          Thanks.
          Your code below is correct, no input field required.
          </select>
          <?php } ?>
          </div>
          Values are retrieved like
          $value = $_POST['howHeard'];
          What ever option is select at the time will get attributed to the $value variable
          • 2. Re: input and select...
            BenPleysier Adobe Community Professional & MVP
            The value that for the select is the chosen option value, as opposed to an input type text (or similar) where the value is placed inside the box.
            As a side note, the label element should have a for-property, referring to the input element.
            • 3. Re: input and select...
              r_tist Level 1
              OK, it's as what I suspected then! - phew! Can't wait to test it later...
              Can you ellaborate on: "As a side note, the label element should have a for-property, referring to the input element."
              Please explain so I can understand.
              Thanks!
              • 4. Re: input and select...
                osgood_ Level 8
                Thanks!
                <label for="howHeard" class="screen-reader-text">How did you hear about this?</label>
                • 6. Re: input and select...
                  r_tist Level 1
                  ok, I added that. as it is powered by php, my page is an .html single page site. my intention is to insert this form into the footer.
                  any recommendations how I can do that? can I copy the form code and insert? do I simply change extension of file to php?
                  (un-chartered territory for me here!)
                  Alternatively, if you know how I can change the code above to make HTML only - that would be fine if easier. I just would like it to function...
                  Thank you!
