2 Replies Latest reply on Feb 22, 2007 10:54 AM by ctzn99
    Odd XML behaviour
    ctzn99 Level 1
      Hello Again,
      I'm having an odd problem that I don't fully understand and I'm hoping for some insight. Basically if I have an XML object declared like
      var xml:XML = <template label="test" />;
      or
      var xml:XML = <tempate label="test"></template>;
      and then use
      Alert.show(xml);
      the alert is an empty box where I was expecting to see the single XML node, but
      var xml:XML = <template label="test"><tab label="my tab" /></template>;
      and then call the same Alert.show it displays the xml as I expect. For some reason when the xml only has one node flex seems to think it's empyt? Or at least that's what I'm led to believe...
      Any thoughts on this? I'm sorta stuck for the night trying to figure out how to get that value to display.
      </zach>
