3 Replies Latest reply on Feb 13, 2015 9:32 AM by m_vargas
    flashplayer background update internal server hosted on apache2-linux - flashinstall.log errors
    NFS
      Hello everybody,
      i have set up an internal update server for flashplayer as described in the latest admin guide (v16).
      The web server hosting the files from the latest fp_background_update.cab is apache2 on SLES11.
      I have configured one client (win7sp1, fully patched) with mms.cfg pointing to the webserver. It has player v14 installed, activex and plug-in.
      From client using any browser i can see and download the files from the webserver.
      But background updater does not install the newer version, flashinstall.log shows that webserver is contacted and that xml-files are processed, but it produdes warning and error codes for which i cannot find any documentation, so tapping in the dark here.
      When looking at the webserver logs i can see following behaviour:
      - Client pulls the majorversion.xml and the version.xml for the new version (v16) - OK
      - Client tries to pull a patch.xml, which does not exist in the fp_background_update.cab. - STRANGE
      - Client pulls the patch.xml (that i manually provided by downloading it via wget to webserver) - OK
      - Client tries to pull whatever it is and causes webserver error 400, what usually means client bad request - BAD
      This is access-log from webserver without and with patch.xml provided:
      - - [12/Feb/2015:10:33:01 +0100] "GET /pub/flashplayer/update/current/sau//currentmajor.xml HTTP/1.1" 200 58 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:33:01 +0100] "GET /pub/flashplayer/update/current/sau/16/xml/version.xml HTTP/1.1" 200 410 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:33:01 +0100] "GET /pub/flashplayer/update/current/sau/16/xml/patch.xml HTTP/1.1" 404 1051 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:33:01 +0100] "GET /" 400 984 "-" "-"
      - - [12/Feb/2015:10:35:46 +0100] "GET /pub/flashplayer/update/current/sau//currentmajor.xml HTTP/1.1" 200 58 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:35:46 +0100] "GET /pub/flashplayer/update/current/sau/16/xml/version.xml HTTP/1.1" 200 410 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:35:46 +0100] "GET /pub/flashplayer/update/current/sau/16/xml/patch.xml HTTP/1.1" 200 823 "-" "Get Flash Player version xml/1.0"
      - - [12/Feb/2015:10:35:47 +0100] "GET /" 400 984 "-" "-"
      This is flashinstall.log without and with patch.xml provided:
      2015-2-12+9-33-1.406 [info] 1628 internal-server.domain
      2015-2-12+9-33-1.406 [info] 1629 internal-server.domain
      2015-2-12+9-33-1.406 [info] 1614
      2015-2-12+9-33-1.406 [info] 1615
      2015-2-12+9-33-1.469 [info] 1618
      2015-2-12+9-33-1.469 [info] 1619 1063
      2015-2-12+9-33-1.484 [info] 1628 internal-server.domain
      2015-2-12+9-33-1.484 [info] 1629 internal-server.domain
      2015-2-12+9-33-1.484 [info] 1614
      2015-2-12+9-33-1.484 [info] 1615
      2015-2-12+9-33-1.500 [info] 1618
      2015-2-12+9-33-1.500 [info] 1604
      2015-2-12+9-33-1.500 [info] 1608
      2015-2-12+9-33-1.500 [info] 1631 /pub/flashplayer/update/current/sau//currentmajor.xml
      2015-2-12+9-33-1.609 [info] 1630 /pub/flashplayer/update/current/sau/16/xml/version.xml
      2015-2-12+9-33-1.609 [info] 1632
      2015-2-12+9-33-1.609 [info] 1630 /pub/flashplayer/update/current/sau/16/xml/patch.xml
      2015-2-12+9-33-1.609 [warning] 1445
      2015-2-12+9-33-1.625 [warning] 1442
      2015-2-12+9-33-1.625 [info] 1632
      2015-2-12+9-33-1.625 [info] 1600
      2015-2-12+9-33-1.625 [error] 1214 12152
      2015-2-12+9-33-1.625 [error] 1234 0
      2015-2-12+9-33-1.640 [info] 1612
      2015-2-12+9-33-1.640 [info] 1620
      2015-2-12+9-35-45.987 [info] 1628 internal-server.domain
      2015-2-12+9-35-46.2 [info] 1629 internal-server.domain
      2015-2-12+9-35-46.2 [info] 1614
      2015-2-12+9-35-46.2 [info] 1615
      2015-2-12+9-35-46.2 [info] 1618
      2015-2-12+9-35-46.2 [info] 1619 1063
      2015-2-12+9-35-46.18 [info] 1628 internal-server.domain
      2015-2-12+9-35-46.18 [info] 1629 internal-server.domain
      2015-2-12+9-35-46.18 [info] 1614
      2015-2-12+9-35-46.18 [info] 1615
      2015-2-12+9-35-46.33 [info] 1618
      2015-2-12+9-35-46.33 [info] 1604
      2015-2-12+9-35-46.33 [info] 1608
      2015-2-12+9-35-46.33 [info] 1631 /pub/flashplayer/update/current/sau//currentmajor.xml
      2015-2-12+9-35-46.143 [info] 1630 /pub/flashplayer/update/current/sau/16/xml/version.xml
      2015-2-12+9-35-46.158 [info] 1632
      2015-2-12+9-35-46.158 [info] 1630 /pub/flashplayer/update/current/sau/16/xml/patch.xml
      2015-2-12+9-35-47.110 [info] 1632
      2015-2-12+9-35-47.110 [info] 1600
      2015-2-12+9-35-47.125 [error] 1214 12152
      2015-2-12+9-35-47.125 [error] 1234 0
      2015-2-12+9-35-47.125 [info] 1612
      2015-2-12+9-35-47.125 [info] 1620
      Hope someone can help and provide documentation of error codes for background update or has ideas, i am bytting out my teeth on this:-)
      Thanks to all
      regards
      Lars
