4 Replies Latest reply on Feb 14, 2015 6:52 AM by joel_pau
    How to get value of text (e.g. text() ) for self
    ta2909i
      Hi all,
      I have a number of text boxes that I use as buttons which configured at the start.
      When clicked they pass on their text value ( using "......text()" ) to a global function and then some magic happens.
      Currently I am using something like:
      var MyVar = sym.$("textbox").text();
      Which means I have to configure for each of my many text boxes e.g.;
           sym.$("textbox"),  sym.$("textbox1"),  sym.$("textbox2"),  sym.$("textbox3"),  .......
      Is there anyway of doing something like:
      var MyVar = sym.$SELF.text();
      So that I can simply copy paste the text boxes and their click triggers dont need to customized.
      Best,
      T
        • 1. Re: How to get value of text (e.g. text() ) for self
          joel_pau Level 5
          Hello,
          Well, your question is not very clear.
          1) You want to create a set. So, you can use a class (Edge UI: c button) or use a tag (Edge UI: tag button).
          2) Then, it seems you want to browse this set. And here i don't understand your goal.
          Can you post a sample file?
          • 2. Re: How to get value of text (e.g. text() ) for self
            ta2909i Level 1
            I don't really have a sample file yet . Because I am trying to figure a work around this issue.
            Basically I have a text box and I want to have a click event trigger that sends the value of its own text (i.e. ".text()").
            • var MyVar = sym.$("textbox1").text();
            However as I have 60+ of these text boxes it will take me a very long time to modify each click trigger so that they have the correct name. E.g.:
            • for "textbox1"        var MyVar = sym.$("textbox1").text();
            • for "textbox2"        var MyVar = sym.$("textbox2").text();
            • for "textbox3"        var MyVar = sym.$("textbox3").text();
            It would be much easier if I could point the ".text()" to "self", rather than opening each click event one by one and making sure that the right text box is referenced.
            BTW - if there is a way to handle click events from a global location then I can also address my problem.  if textbox1 pressed, then.... if textbox2 pressed, then.... if textbox3 pressed, then.... etc...
            Best,
            T
            • 3. Re: How to get value of text (e.g. text() ) for self
              joel_pau Level 5
              • How to manage several elements using classes or tags? A demo file to download: classes tags events.zip - Box
              • About events: you have an example (demo file). An event function and e.target can be used.
              • 4. Re: How to get value of text (e.g. text() ) for self
                joel_pau Level 5
                About your "self" word:
                It seems you want: new text = current text + a text.
                Then: sym.$("Text").text( sym.$("Text").text() + "added text" ) ;
