1 Reply Latest reply on Feb 14, 2015 11:57 PM by station_two
    I run a Windows 8.1 -  Photoshop CS5 under Parallels on an iMac one year old and both having the latest OS. I use a NIK plugin "VIVEZA" which run fine for years without a problem. Latelt and without a reason, the NIK plugin has gone corrupt, (can not use
    hermansgallery
      @I run a Windows 8.1 -  Photoshop CS5 under Parallels on an iMac one year old and both having the latest OS. I use a NIK plugin "VIVEZA" which run fine for years without a problem. Latelt and without a reason, the NIK plugin has gone corrupt, (can not use it more the 2 corrections after a get a black background message that there is not enough memory) and the system stops running and a must restart is required. How do I fix this terrible problem?
      If it requires a Photoshop CS5 re-install, (I belief that it may fix the problem) and re-install the two third party plugins (NIK Viveza) and (Onone Perfect Resize) how and where do I get to the proper Adobe upload page to do that.
      I have tried to fix this problem by changing the memory allocations, I have spend many hours on it and are very disgusted with it but it needs to be fixed. The current memory settings are;
      Ram available = 1588 MB
      Range = 873 -1143 MB
      Recommended Photoshop usage range =  857  however I have tried every setting to max and in between. Nothing works. Current setting = 1588 (max)
      The Photoshop I use is registered, I have product # and order # .
