8 Replies Latest reply on Feb 18, 2015 7:57 AM by A.T. Romano
    premier elements 10. Quits when opening "get files from..."
    luiscue
      How do I fix this issue: APE10 open, sets up a new project, but when I try to "get files" from "files an folders" it quits.
        • 1. Re: premier elements 10. Quits when opening "get files from..."
          A.T. Romano Level 7
          luiscue
          What computer operating system is your Premiere Elements 10 running on? And, the most important introductory question "What video card/graphics card does your computer use?"
          NVIDIA GeForce?
          Is this a "it worked before but not now issue" or "it never worked before" type?
          If it worked before, how long ago?
          Let us start here and then we can decide what next in the way of troubleshooting strategy. Lots more questions, dependent on your answers to the above.
          We will be watching for your reply.
          Thank you.
          ATR
          • 2. Re: premier elements 10. Quits when opening "get files from..."
            luiscue Level 1
            OS 10.10.2
            It worked well 3 months ago. First time it has done it.
            8GB RAM
            NVIDIA GeFORCE 9400M 256MB
            • 3. Re: premier elements 10. Quits when opening "get files from..."
              A.T. Romano Level 7
              luiscue
              There is a serious known issue with Premiere Elements 10 on a computer that uses a NVIDIA GeForce video card/graphics card. The answer to date has been to roll back
              the driver version to about May 2013. There is an Announcement at the top of this forum about all this, and much more information to be found elsewhere
              ATR Premiere Elements Troubleshooting: PE10: NVIDIA Video Card Driver Roll Back
              I am not sure if an automatic update of the driver version may have taken the driver version from the much older date to current version which is triggering your present situation.
              I am strictly an Elements Windows user so I am not sure if the following NVIDIA GeForce 9400 M driver version would work in your Mac computer environment.
              GeForce 320.49 May 23, 2013. The following is the NVIDIA GeForce 9400 M but listed on Windows
              NVIDIA Driver Downloads - Advanced Search
              The other consideration is the use of Premiere Elements 10 OS10.10.2. I have not seen any reports confirming that Premiere Elements 10 is compatible with OS 10.10.2.
              But then again, you report "It worked well 3 months ago. First time it has done it." Where you using the same operating system then as now?
              You can also factor into all this the usual drill considerations...
              a. Are you working with a pen and tablet device instead of mouse?
              b. Does the problem exist with antivirus and firewall(s) disabled?
              c. Have you deleted the Adobe Premiere Elements Prefs file
              Users/Owner/Libraries/Application Support/Adobe/Premiere Elements/10.0
              d. Is the latest version of QuickTime installed on your computer?
              Please review and consider and then we can discuss this further.
              Thank you for the follow up.
              ATR
              Add On..Since I am strictly an Elements Windows user, please indicate anywhere in the above where the question would not be applicable to Mac.
              • 4. Re: premier elements 10. Quits when opening "get files from..."
                luiscue Level 1
                Technical support at Adobe sent me to the Forum to get help with my issue because they don't have technical support for their products
                Amit Kumar: You need to go to forums.adobe.com regarding technical issues.
                Luis Cuenca: I did go to forums and the only person that responded was a windows one, not a mac.
                Luis Cuenca: you can't help me?
                Amit Kumar: We do not have chat support regarding technical issues.
                So
                A.T. Romano's suggestions did not solve the issue.
                Do I have to reinstall
                and
                Will that solve the issue?
                • 5. Re: premier elements 10. Quits when opening "get files from..."
                  A.T. Romano Level 7
                  luiscue
                  Disappointing news. I had not realized that Ask the Community is now the sole avenue for Premiere Elements technical support.
                  Nonetheless, let us see what we can do.
                  1. Does your computer use a NVIDIA Ge Force video card/graphics card? If not, that is out of the way. If your Mac computer does use a NIVIDIA GeForce card, then that is a troubleshooting target in view of the specific Photoshop Elements 10/NVIDIA GeForce situation.
                  2. Did you rule out the following
                  3. Have you gone through
                  a. uninstall
                  b. free ccleaner run through
                  CCleaner - Download
                  c. reinstall with antivirus and (if applicable) firewall(s) disabled.
                  4. If all else fails, for troubleshooting purposes only at this time, consider downloading and
                  installing the free 30 days tryout of Premiere Elements 13 from Adobe. This a win win situation which is hoped
                  to point to either your computer or to the programs.
                  Please consider.
                  ATR
                  • 6. Re: premier elements 10. Quits when opening "get files from..."
                    luiscue Level 1
                    ATR
                    Thank you
                    After going through all your suggestions, at the end I had to uninstall and install
                    It's working fine now
                    Thanks for taking the time to help (something Adobe doesn't do anymore for their "older" versions)
                    As you perfectly stated
                    "... Ask the Community is now the sole avenue for Premiere Elements technical support."
                    Luis
                    • 7. Re: premier elements 10. Quits when opening "get files from..."
                      A.T. Romano Level 7
                      Luis
                      Thanks for the update. We are so pleased to learn of your success.
                      Your follow up is appreciated.
                      Best wishes
                      ATR
                      • 8. Re: premier elements 10. Quits when opening "get files from..."
                        A.T. Romano Level 7
                        In post numbered 5 to Luis, I mention
                        the should have been
                        in view of the specific Premiere Elements 10/NVIDIA GeForce situation.
                        I cannot get into the post to make the correct. Otherwise everything else (details) stays as written for Premiere Elements issue.
                        ATR
