0 Replies Latest reply on Feb 25, 2007 9:55 AM by romanczar
    Determining exact size in changing application
    romanczar Level 1
      Hi!
      I am building a small tool which will be included in an HTML Page. The content will be dynamically created based on an XML file. Therefor I can not set fixed pixel height and width values. The toll uses two views of a viewstack (I could also change it to states), one of them is higher than the other.
      When I include the SWF file into my HTML code I must set height and width. The width is simply 100% as the surrounding table determines its borders. But the height is my problem.
      I want to avoid scrolling bars inside the flash. Therefor I created a JavaScript which can change my SWF height dynamically. But it needs to know the exact value from inside the SWF.
      The connection is not problem.
      BUT: How the f**k do I get the CHANGING height of the whole application? Most of the content it added through a AS method triggered my the applications "creationComplete" method.
      Does anybody have an idea?
