0 Replies Latest reply on Mar 1, 2007 6:35 AM by RazvanPat
    Text Metrics
      I need to know how flash calculates the distance between text rows when using textField. What is the default leading? Documentation says it's undefined.. but what does undefined mean? 0? Also I need to know what is the distance from the top of the textfield to the first line of text.
      I found out that by inserting a dynamic text on stage in flash and setting it's line spacing to -fontsize/3 pt gives me the result I am looking for. What is the relation between the pt used for line spacing and the values entered at leading property in TextFormat?
      The problem I am experiencing is that I try to generate a pdf based on information gathered in flash. Everything works except the text component. Text is rendered completely different and I can't find a pattern to figure out a formula for matching them. Different fonts have completely different line spacings.
      Fonts are embedded in flash. Could this be an issue?
