3 Replies Latest reply on Feb 18, 2015 6:41 AM by kglad
    Array from Movieclip items
    JonnyDL Level 1
      *Mistakenly posted in Flash builder forum, This was the correct forum. Sorry if you saw it twice.
      Im attempting to build a picture carousel. The goal is to load Moviclips into an empty movieclip and have them fade in and out based on a click of a button. I'm loading them into empty movieclip so I can count them, to build corresponiding buttons for each one (on the stage). The problem I am having is getting these into an array that I can then take from and tween.
      I make a for loop counting the Movilips in the container, (attempt to load them in an array) picArray.push(container[i]._name), but when I try to take it and tween it nothing happens.
      Im guessing it has something to do with they way Im putting into the array or trying to reference in the tween (that it is still an object stored in the array)
      Any body got a good way to load up the array in a way to use/tween the movieclip items
      Hopefully this makes sense, Oh I'm writing this in AS2, hopefully when we make our upgrade I will take it and convert it to AS3
        • 1. Re: Array from Movieclip items
          movieclips aren't 'loaded'.  swfs can be loaded so i'm assuming that's what you mean.  if that's so:
          you'll reference the loaded swfs using the load targets.  ie, put the loadMovie targets into your array if you're trying to use the array to control the loaded swfs.
          • 2. Re: Array from Movieclip items
            JonnyDL Level 1
            Kglad
            Sorry I got to general in terms, and I can see the misunderstanding. (my bad) cIm not working with swf Im working with Movieclips
            var album:MovieClip = this.createEmptyMovieClip("album", this.getNextHighestDepth())
            album.attachMovie("picOne", "instance1", album.getNextHighestDepth());
            album.attachMovie("picTwo", "instance2", album.getNextHighestDepth());
            album.attachMovie("picthree", "instance3", album.getNextHighestDepth());
            I then use a for loop to count the MCs in album
                      Place a button on the stage for every MC in album
                      And push them into an array ( I think an assocative array (button = MC) would work better to match button with specific MC)
            * I make a for loop counting the Movilips in the container, (attempt to load them in an array) picArray.push(container[i]._name), but when I try to take it and tween it nothing happens.
            Hopefully this clears up the question. Any body got a good way to load up the array in a way to use/tween the movieclip items.
            • 3. Re: Array from Movieclip items
              push what into an array, the buttons?
              what movieclips, the attached ones?  if so, why?  you can already loop through them using their parent, 'album'.
              in the container
              what container, album?
              there's no container array shown and _name properties are strings, not objects so you can't tween those.
              anyway, there's no reason to create buttons.  just assign mouse handlers to the children of album that do what ever you want.
              in a carousel, typically clicking a carousel item would stop the carousel and enlarge the clicked item, or spin the carousel quickly so the clicked item appears front and center and enlarge it.  in either case there's no need for buttons in addition to the carousel movieclips that you attached to album.
