4 Replies Latest reply on Feb 25, 2007 11:24 AM by Opera Rat
    converting millisecs to min and sec
    Opera Rat
      I have to turn milliseconds into minutes and seconds for an extra I am using. (Unfortunately the one command that I really need only does TMSF (Track, minutes, seconds, frame). Everything else uses milliseconds. So say I have 164000 milliseconds, that's 2.73 minutes. I need to take the 2 and put it assign it a variable then I need to take the .73 and turn it into seconds, that 43.8 (44) seconds. And I need to assign that a variable. So that I can get my variables into
      dmm_CDExtPlayFromTMSF(gTrack, gMin, gSec, 0)
      Don't worry about the last number (frame), I don't know what that's all about yet.
      Here is my sad start
      --gMark is the milliseconds
      gMin = gMark/60000 (and ignore anything after the decimal point WITHOUT ROUNDING UP OR DOWN)
      gSec = ??
      Basically, I want to parse not round the result of gMark/60000
      Can anyone show me the way to do this?
        • 1. Re: converting millisecs to min and sec
          James Newton, ACP Level 3
          on MSToHMS(aMilliseconds) ---------------------------------------------
          -- INPUT: <aMilliseconds> must be a postive integer
          -- ACTION: Converts aMilliseconds to a string with the format
          -- "H:MM:SS" or "M:SS", where H is an integer number of hours
          -- greater than 0, M is an integer number of minutes and
          -- S is an integer number of seconds. Any incomplete
          -- seconds (up to 999 milliseconds) are truncated.
          -- OUTPUT: Returns a string
          vSeconds = aMilliseconds / 1000
          vMinutes = vSeconds / 60
          vHours = vMinutes / 60
          vMinutes = vMinutes mod 60
          vSeconds = vSeconds mod 60
          if vHours then
          if vMinutes < 10 then
          vMinutes = "0"&vMinutes
          end if
          vString = vHours&":"&vMinutes&":"
          else
          vString = vMinutes&":"
          end if
          if vSeconds < 10 then
          put "0"&vSeconds after vString
          else
          put vSeconds after vString
          end if
          return vString
          end MSToHMS
          • 2. Re: converting millisecs to min and sec
            Opera Rat Level 1
            Thank you. That got me my integers, but now I get an error message:
            integer expected
            dmm_CDExtPlayFromTMSF(gTrack,gMin,gSec,0)
            1
            Well last I checked 1 is an integer. It's not "1".
            Here is the full script:
            global gTrack, gMark, gMin, gSec
            on mousewithin
            set the moveablesprite of Sprite 9 to true
            cursor 293
            ConvertFromMillSecs
            ScrubMusic
            end
            on MouseDown
            dmm_CDExtPause()
            end
            on ConvertFromMillSecs
            vSeconds = gMark / 1000
            if vHours then
            end if
            else
            end if
            else
            end if
            the itemDelimiter = ":"
            tMin = vString.item[1]
            tSec = vString.item[2]
            the floatPrecision = 0
            gMin = float(tMin)
            gSec = float(tSec)
            return vString
            end
            on mouseUp
            end
            It doesn't mind the gTrack which is a variable for an integer. So why not gMin, or gSec?
            • 3. Re: converting millisecs to min and sec
              Level 7
              I don't know why it does that, but I think it is a problem with the way
              the xtra is reading in the values. It should work if you explicitly
              force the params to be integers:
              dmm_CDExtPlayFromTMSF(integer(gTrack),integer(gMin),integer(gSec),0)
              • 4. Re: converting millisecs to min and sec
                Opera Rat Level 1
                Wouldn't you know? Today, Feb. 25, 2007, a new version of the Xtra came out and it includes dmm_CDExtPlayFromMilliseconds. But your script did work once I changed gMin = integer(tMin) and same for tSec. Thanks for your help
