3 Replies Latest reply on Feb 16, 2015 11:09 PM by richardh37332259
    how to send 4 8X10s to make one photo to a lab
      In LR, I have a problem sending 4 8X10's as one photo that tells a story of a elephant drinking from a dry river bed, then drinking, then reloading, then spraying himself. I made a 4 8X10 template in LR Print module, but putting the correct order in the film strip into a 4 8X10 doesn't transfer in the correct order. One cannot drag & drop in the right order either.It won't take. By trial & error in placing the order in the film strip out of order, I finally had the order in 4 8X10s as one picture.In making a copy of the all the pictures on my photosmart 8450printer, on an 8x10 photo paper, to test the 4 photos, The top two photos are washed out. So I don't know if I send the 4 8X10s to the lab will be Ok. So how do I make 4 8X10's onto say a 16X20 with 3 mm space between the the photos to to send to the Bayphoto lab as they require. Richard Haars
        • 1. Re: how to send 4 8X10s to make one photo to a lab
          If you can get the for images onto a page in the order that you want them then you can change the print destination to file and you can print that to a JPEG file that can be sent to the printer. But in order to make it 16 x 20" it seems to me that you would have to have printer that supported paper that big. I don't know if the exported JPEG would be large enough for what you are looking for or not.
          • 2. Re: how to send 4 8X10s to make one photo to a lab
            WobertC Adobe Community Professional
            My procedure-
            1. Select folder or collection containing the 4 images. Go to Print module.
            2. Click Page Setup:     select 16x20inch paper (landscape or portrait) My image is A2.
               (I don't know what to do here if you don't have a connected printer that is capable of 16x20inch. Although my printer prints up to 8x10inch but shows larger paper sizes in its setup dialog. Maybe other experts have this answer.!)
            3. Select "Custom Package"  (Allows your desired sort order!)
            4. In "Rulers Grids & Guides" tick for ON, Set Grid Snap=Grid
            5. In "Cells" Panel:     Add to package 8x10inch cell. Repeat for 4 cells.
            6. Click on each cell to adjust size, drag position, or rotate.
            7. Drag each wanted photo into desired cells from the film-strip- your sort.
            8. Set "Print to JPG":     Click "Print to File, and save the new 16x20 JPG image for commercial printing.
            • 3. Re: how to send 4 8X10s to make one photo to a lab
              richardh37332259 Level 1
              It took me a while to find "Print to Jpeg" then I stored the image on an external HD and couldn't retrieve it. So the only choice was to store it on the computer HD, Then I could send it. Thanks Richard Haars
