1 Reply Latest reply on Feb 16, 2015 3:04 PM by robdillon
    Flash Library Display
    elyse18 Level 1
      How can I view symbols in the Flash CC2014 Library instead of Text with Use Counts etc?
        • 1. Re: Flash Library Display
          robdillon Most Valuable Participant
          When you select an item in the Library you should see a graphical representation of that item at the top of the Library window. If you do not see that then the top portion of the window may be closed. Move your cursor slowly from the top of the Library window down. You should see it change to a split window indicator. Drag down to see the graphic.
