1 Reply Latest reply on Feb 17, 2015 10:58 PM by julkjen
    Same calculation in drag and in drop gives different results
    julkjen
      I'm using jqueryUI drag and drop to drag an object (ventil_roerHANDLE) on the X axis, then I have another object (ventil_roer) that is repositioned acording to the first objects x positon, and I do a calculation to determine how far on the Y axis the second object should move.
      When I calculate in the drag function the calculation is slightly of, but when I do the same calculation in the drop function, it is correct - ant clues as to why?
      I now have to reposition the second object again in the drop function to get it to where it should be, causing it to "jump" slightly when dropped
      Link to project: Vasskrafta - interaktivt kraftverk
      click on one of the two small grey houses, and then drag on the black valve with the green arrows
      Here's the relevant code
      sym.$('ventil_roerHANDLE').draggable( //MAGASINKRAFTVERK
        containment:container,
        axis: 'x',
        snap: 'draggableArea',
        snapmode: 'inner',
        snapTolerance: 10,
        drag: function( event, ui )
             if(sym.MyGlobalVar_startPosition_mag == 0)
                  sym.MyGlobalVar_startPosition_mag = 1;
                  sym.MyGlobalVar_yStartPosition = Math.round(sym.$('ventil_roerHANDLE').position().top);
                  sym.MyGlobalVar_xStartPosition = Math.round(sym.$('ventil_roerHANDLE').position().left);
                  sym.MyGlobalVar_yPrevPosition = Math.round(sym.$('ventil_roerHANDLE').position().top);
                  sym.MyGlobalVar_xPrevPosition = Math.round(sym.$('ventil_roerHANDLE').position().left);
             //utregninger for å posisjonere den synlige ventilen
             var xPosition = Math.round(sym.$('ventil_roerHANDLE').position().left);
             var xPositionCopy = Math.round(sym.$('ventil_roer').position().left);
             var yPositionCopy = Math.round(sym.$('ventil_roer').position().top);
             var xPosChange = xPositionCopy - xPosition;
             var yPosChange = xPosChange * 0.48;
             var newXPos = Math.round(sym.$('ventil_roerHANDLE').position().left);
             var newYPos = Math.round((sym.$('ventil_roer').position().top) - yPosChange);
             sym.MyGlobalVar_newYPos = newYPos;
             sym.MyGlobalVar_newXPos = newXPos;
             sym.$('ventil_roer').css(
             'left': newXPos,
             'top': newYPos
      sym.$('draggableArea').droppable( //MAGASINKRAFTVERK
        tolerance: 'touch',
        drop: function()
             //utregninger for å posisjonere den usynlige ventilen
             var xPositionCopy = sym.MyGlobalVar_xPrevPosition;
             var newYPos = Math.round((sym.$('ventil_roerHANDLE').position().top) - yPosChange);
             //bytt topp posisjon på den usynlige ventilen (HANDLE)
             sym.$('ventil_roerHANDLE').css(
                  'top': newYPos
             //reset prev X og Y posisjoner
             //flytt  ventilen til HANDLEs posisjon
                  'left': sym.MyGlobalVar_xPrevPosition,
                  'top': sym.MyGlobalVar_yPrevPosition
