7 Replies Latest reply on Feb 18, 2015 9:23 AM by K.Daube
    Add paragraphs with text
    K.Daube Level 1
      Dear patient helpers,
      I want to 'dump' the contents of an array into a series of paragraphs. Two problems appear in my script:
      - inserting a TAB by \t inserts a NewLine
      - items are not placed in succesive paragraphs but at the start of the flow - hence in reverse order and not in own paragraphs
      // write array to multiple paragraphs
        var items      = new Array ();
        var nItems, pgf, textLoc, oDoc;
        items = ["Århus", "Çedille", "Dandy"];
        nItems = items.length;
        oDoc = app.ActiveDoc;
        pgf = oDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;  // get first pgf in flow
        textLoc = new TextLoc (pgf, 0);
        for (var i = 0; i < nItems; i += 1) {
          insText = items[i];
          oDoc.AddText (textLoc, insText + "\t" + insText); // \t insert a NL...
          oDoc.NewSeriesObject(Constants.FO_Pgf, pgf);  // add a paragraph
          pgf = oDoc.NextPgfInFlow;
        • 1. Re: Add paragraphs with text
          Klaus Göbel Level 3
          Hi Klaus,
          first of all you should swap lines 9 and 10, because you ALWAYS use the same textLoc. And so all textitems are inserted at the beginning.
          • 2. Re: Add paragraphs with text
            K.Daube Level 1
            Thanks Klaus, for the idea.
            However the result of this swap is that for the second iteration (i=1) I get the error on this line :
            Bad argument {LiveObject("TextLoc").property(0)}.
            Obviously i do not understand the concepts of text location and paragraphs ...
            • 3. Re: Add paragraphs with text
              K.Daube Level 1
              At least one step further:
              To get a TAB inserted, the string must be "\x08" and not "\t" or "\x09".
              And with the following code i get additional paragraphs, but the textloc does not advance into these.
                  insText = items[i];
                  oDoc.AddText (textLoc, insText + "\x08" + insText); // \t inserts a NL...
                  oDoc.NewSeriesPgf(pgf);                       // add a paragraph
              • 4. Re: Add paragraphs with text
                Klaus Göbel Level 3
                your last line is missing now : pgf = oDoc.NextPgfInFlow;
                1. for (var i = 0; i < nItems; i += 1) {
                2.     textLoc = new TextLoc (pgf, 0);
                3.     insText = items[i];
                4.     oDoc.AddText (textLoc, insText + "\x08" + insText); // \t inserts a NL...
                5.     oDoc.NewSeriesPgf(pgf);                       // add a paragraph
                6.     pgf = oDoc.NextPgfInFlow;
                7.   }
                • 5. Re: Add paragraphs with text
                  K.Daube Level 1
                  Klaus, it seems that the situation is more complicated.
                  Adding the missing line creates the error
                  for line 9 (your line 2).
                  Not understanding the required functions/methods my approach resembles "im nebel stochern" -  poking in the fog. Unfortunately there are no examples for this case available (and I'm still in the early chinese phase aka copying existing solutions) - most use of eScript handles existing content - but I want to create some content.
                  • 6. Re: Add paragraphs with text
                    Klaus Göbel Level 3
                    Hi Klaus,
                    just change your last line from
                    to :
                    pgf = oDoc.NewSeriesPgf(pgf);
                    that should do it.
                    So you directly point to the new pgf.
                    completely :
                            insText = items[i];
                           if (i < nItems -1){
                            pgf = oDoc.NewSeriesPgf(pgf);                       // add a paragraph
                    • 7. Re: Add paragraphs with text
                      K.Daube Level 1
                      Klaus, congratulation!
                      This is the solution. The script now works as intenden!
                      How many beers do I owe You? (a well, today is Ash Wednesday, so for me there is no beer in reach).
