1 Reply Latest reply on Feb 26, 2007 1:44 PM by peterent
    HTTPService feeding ComboBox
    ChrisDut
      Hello Everybody,
      I have a problem feeding XML data in a combobox .
      <mx:HTTPService
      id="GetActivities"
      result="ShowActivities()" ( I do nothing here )
      fault="requestErrorHandler(event)"
      showBusyCursor="true"
      url= " http://localhost/party_apps/GetActivities.cfm">
      </mx:HTTPService>
      <mx:ArrayCollection id="ActivitiesList" source="{ArrayUtil.toArray(GetActivities.lastResult.activities.item)}"/>
      <mx:ComboBox dataProvider="{ActivitiesList}" labelField="description" x="544" y="63" id="Activity0" fontSize="11"/>
      <?xml version="1.0" encoding="UTF-8"?>
      <activities>
      <item>
      <ID>1</ID>
      <description>Administration / Secteur public</description>
      </item>
      <item>
      <ID>2</ID>
      <description>Associations / Fédérations / Syndicats</description>
      </item>
      <item>
      <ID>3</ID>
      <description>Automobile</description>
      </item>
      <item>
      <ID>4</ID>
      <description>Education</description>
      </item>
      <item>
      <ID>5</ID>
      <description>Energie</description>
      </item>
      <item>
      <ID>6</ID>
      <description>Immobilier / Construction</description>
      </item>
      </activities>
      GetActivities.send() is executed on initialize of the mx:application
      My combobox gets filled with [object Object], [object Object],[object Object],[object Object],[object Object], ...
      What am I doing wrong ?
      Thanks in advance for your help, have a nice day,
      Chris.
        • 1. Re: HTTPService feeding ComboBox
          peterent Level 2
          In this case you do not want to use ArrayUtil. The result from your service is XML, not something you want to turn into an Array.
          The lastResult.activities.item is an XMLList - even if it has 1 element. That's a great parameter to give to XMLListCollection:
          <mx:XMLListCollection id="ActivitiesList" source="{GetActivities.lastResult.activities.item}" />
          Use that instead of ArrayCollection.
