1 Reply Latest reply on Feb 18, 2015 4:57 AM by Jump_Over
    Script UI 89858 error
    Johnwhite Level 1
      Hi everyone
      I change the script into this
      but cause 89858 error
      so can some fix this error?
      Regard
      John
                  function doSomething(myEvent1){
                     var cSelected = ddown.selection.index;
                     if (myEvent1.keyName === "Up") {
                          if (cSelected == ddown.items.length - 1) {
                              ddown.selection = ddown.items[0]; return;
                           if (ddown.items[cSelected + 1].type == "item") {
                              ddown.selection = ddown.items[cSelected + 1]; return;
                          else ddown.selection = ddown.items[cSelected + 2];
                          return;
                       if (myEvent1.keyName === "Down") {
                          if (cSelected == 0) {
                              ddown.selection = ddown.items.length - 1; return;
                           if (ddown.items[cSelected - 1].type == "item") {
                              ddown.selection = ddown.items[cSelected - 1]; return;
                          else ddown.selection = ddown.items[cSelected - 2];
                          return;
                  for(var n=0;n<myStringList.length;n++){
                      if(myEvent1.keyName === String(Number(myStringList[n].replace(/^0+/,"")))){
                          ddown.selection = n;
                          break;
                  //Array of strings:
                  var myStringList =
                          "1 General",
                          "2 Special",
                          "3 Others"
                  var w = new Window ("dialog", "Change by list");
                  var ddown = w.add ("dropdownlist", undefined, myStringList);
                  ddown.minimumSize.width = 200;
                  ddown.selection = 0;
                  ddown.active = true;
                  w.addEventListener ("keydown", doSomething);
                      b = w.add("group");
                      b.add ('button', undefined, "OK", {name: "OK"});
                      b.add ('button', undefined, "取り消す", {name: "Cancel"});
      if (w.show() == 1){
        app.selection[0].tables.everyItem().convertToText("\t", "\r");
        main();
      // dropdown list assigned and return to nothing so cause 89858 error
      function main(){
        var myObject;
        var myCheckSelection = false;
        if(app.documents.length > 0){
        if(app.selection.length > 0){
        switch(app.selection[0].constructor.name){
        case "InsertionPoint":
        case "Character":
        case "Word":
        case "TextStyleRange":
        case "Line":
        case "Paragraph":
        case "TextColumn":
        case "Text":
        myObject = app.selection[0];
        if(myObject != "None"){
        myFindChangeByList(myObject, true);
                                  app.findTextPreferences = NothingEnum.nothing;
                                  app.findTextPreferences.capitalization = Capitalization.ALL_CAPS;
                                  app.findChangeTextOptions.wholeWord = false;
                                  var myFoundItem = app.activeDocument.findText()
                                  for ( i = myFoundItem.length-1; i >= 0 ; i-- )
                                  changeUpperCase( myFoundItem[i] );
                                  function changeUpperCase ( myFound )
        myFound.capitalization = Capitalization.normal;
        myFound.changecase( ChangecaseMode.uppercase );
        } // if
        } // switch
        } // if
        } // if
        else alert("No documents are open. Please open a document and try again.");
      function myFindChangeByList(myObject, myCheckSelection){
        var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
        var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit;
        var myStartCharacter, myEndCharacter;
          if (myStringList == 0){
              var myFindChangeFile = myFindFile("/ClearRubbishSupport/FindChangeList[1tab]-E.txt");
          else if (myStringList == 1){
              var myFindChangeFile = myFindFile("/ClearRubbishSupport/ClearRubbish[enrule]_E.txt");
        else if (myStringList == 2){
              var myFindChangeFile = myFindFile("/ClearRubbishSupport/midas&chuangs_E.txt");
        if(myFindChangeFile != null){
              // Because the selection will change as we add/remove characters,
              // we'll need to reset the selection after each pass if we are
              // checking the selection. We'll get the index of the first character
              // in the selection (relative to the start of its parent story) and
              // the index of the last character in the selection (relative to the
              // *end* of the story, and we'll use them later in the script to
              // keep the ends of the selection in place.
        if(myCheckSelection == true){
        var myStart = myObject.characters.item(0).index;
        var myEnd = myObject.characters.item(-1).index;
        var myStory = myObject.parentStory;
        var myStoryEnd = myStory.characters.item(-1).index;
        myEnd = (myStoryEnd - myEnd)+1;
        myFindChangeFile = File(myFindChangeFile);
        var myResult = myFindChangeFile.open("r", undefined, undefined);
        if(myResult == true){
        //Loop through the find/change operations.
        do{
        myLine = myFindChangeFile.readln();
        //Ignore comment lines and blank lines.
        if((myLine.substring(0,4)!="text")||(myLine.substring(0,4)!="grep")||(myLine.substring(0, 5)!="glyph")){
        myFindChangeArray = myLine.split("\t");
        //The first field in the line is the findType string.
        myFindType = myFindChangeArray[0];
        //The second field in the line is the FindPreferences string.
        myFindPreferences = myFindChangeArray[1];
        //The second field in the line is the ChangePreferences string.
        myChangePreferences = myFindChangeArray[2];
        //The fourth field is the range--used only by text find/change.
        myFindChangeOptions = "{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}";
        switch(myFindType){
        case "text":
        myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
        case "grep":
        myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
        case "glyph":
        myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
        break;
        myStartCharacter = myStory.characters.item(myStart);
        myEndCharacter = myStory.characters.item(-myEnd);
        myObject = myStory.texts.itemByRange(myStartCharacter, myEndCharacter);
        app.select (myObject);
        } while(myFindChangeFile.eof == false);
        myFindChangeFile.close();
      function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
        //Reset the find/change preferences before each search.
        app.changeTextPreferences = NothingEnum.nothing;
        app.findChangeTextOptions = NothingEnum.nothing;
        var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
        myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
        myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
        app.doScript(myString, ScriptLanguage.javascript);
        myFoundItems = myObject.changeText();
        //Reset the find/change preferences after each search.
      function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
        //Reset the find/change grep preferences before each search.
        app.changeGrepPreferences = NothingEnum.nothing;
        app.findGrepPreferences = NothingEnum.nothing;
        app.findChangeGrepOptions = NothingEnum.nothing;
        var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
        myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
        myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
        var myFoundItems = myObject.changeGrep();
        //Reset the find/change grep preferences after each search.
      function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
        //Reset the find/change glyph preferences before each search.
        app.changeGlyphPreferences = NothingEnum.nothing;
        app.findGlyphPreferences = NothingEnum.nothing;
        app.findChangeGlyphOptions = NothingEnum.nothing;
        var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
        myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
        myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
        var myFoundItems = myObject.changeGlyph();
        //Reset the find/change glyph preferences after each search.
      function myFindFile(myFilePath){
        var myScriptFile = myGetScriptPath();
        var myScriptFile = File(myScriptFile);
        var myScriptFolder = myScriptFile.path;
        myFilePath = myScriptFolder + myFilePath;
        if(File(myFilePath).exists == false){
        //Display a dialog.
        myFilePath = File.openDialog("Choose the file containing your find/change list");
        return myFilePath;
      function myGetScriptPath(){
        try{
        myFile = app.activeScript;
        catch(myError){
        myFile = myError.fileName;
        return myFile;
        • 1. Re: Script UI 89858 error
          Jump_Over Level 5
          Suggest two modifications:
          1. move marked line from this a part:
          if (w.show() == 1){
            main();
          here:
          2. Modify this line:
              if(myObject != "None") {
               like:
               if(myObject){
               or just remove this line (remember  closing "}" bracket)
          Jarek
