7 Replies Latest reply on Feb 18, 2015 11:12 AM by BKBK
    The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
    markh21414623
      I am currently testing our website with CF11. It is currently working with CF8 however after migrating it to a new server running CF11 I have encountered the following error.
      The value returned from the load function is not of type numeric.
      The error occurred in
      D:/Applications/CFusion/CustomTags/nec/com/objects/address.cfc: line 263
      Called from D:/Applications/CFusion/CustomTags/nec/com/objects/contact.cfc: line 331
      Called from D:/Applications/CFusion/CustomTags/nec/com/objects/user.cfc: line 510
      Called from D:/Applications/CFusion/CustomTags/nec/com/objects/user.cfc: line 1675
      Called from D:/website/NECPhase2/action.validate.cfm: line 54
      261 : <cfif isNumeric(get.idCountry)>
      262 : <cfset rc = this.objCountry.setID(get.idCountry)>
      263 : <cfset rc = this.objCountry.load()>
      264 : </cfif>
      265 : <cfset this.sPostcode = get.sPostcode>
      Have there been any changes between CF8 and CF11 that could  cause this error?
      Does anyone have ideas?
        • 1. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
          Dave Ferguson Level 3
          There have been tons of changes from 8 to 11.  Can you share the code that the error is referencing?
          • 2. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
            markh21414623 Level 1
            Thank you for your quick reply.
            Here is the section of code from address.cfc that the error points at:
            <cfquery name="get" datasource="#sDatasource#">
                SELECT idAddressID, RTRIM(sAddressLine1) as sAddressLine1, RTRIM(sAddressLine2) as sAddressLine2, RTRIM(sAddressLine3) as sAddressLine3, RTRIM(sTown) as sTown, RTRIM(sCounty) as sCounty, RTRIM(sPostcode) as sPostcode, idCountry
                FROM tblAddress
                WHERE idAddressID = #this.idAddressID#
               </cfquery>
               <cfcatch>
                <cfscript>
                 objError = CreateObject("component","nec.com.system.errors");
                 iErrorID = objError.addError("load: get: #cfcatch.detail#");
                </cfscript>
                <cfset this.iErrorID = iErrorID>
                <cfreturn iErrorID>
               </cfcatch>
              </cftry>
              <cfset this.idAddressID = get.idAddressID>
              <cfset this.sAddressLine1 = get.sAddressLine1>
              <cfset this.sAddressLine2 = get.sAddressLine2>
              <cfset this.sAddressLine3 = get.sAddressLine3>
              <cfset this.sTown = get.sTown>
                    <cfset this.sCounty = get.sCounty>
              </cfif>
              <cfset this.iErrorID = "">
              <cfreturn true>
            The idCountry in the cfquery is an integer value. Which should return a string value such as "United Kingdom" from this.objCountry mentioned in the script below.
            This script may also assist:
            <cfscript>
              this.idAddressID = 0;
              this.sAddressLine1 = "";
              this.sAddressLine2 = "";
              this.sAddressLine3 = "";
              this.sTown = "";
              this.sCounty = "";
              this.sPostcode = "";
              this.objCountry = CreateObject( 'component', 'nec.com.objects.country' );
              this.iErrorID = "";
            </cfscript>
            I have noticed similar errors that fail on lines containing  <cfset rc = this.XXXXXX.load()>. Has something changed with the way CF11 handles this code?
            • 3. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
              Can you share the code from here:    this.objCountry = CreateObject( 'component', 'nec.com.objects.country' );
              That is where the issue is going to be.. not with the calling code.  Please try not to put in just an excerpt as you may cut off something important.
              • 4. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
                This is the code in file object file country.cfc (nec.com.objects.country):
                <cfcomponent displayname="Country object" hint="This is a Country object, it allows you to access and set values in the Country.">
                // Construct this object
                <cfset this.objFunctions = CreateObject( 'component', 'nec.com.system.functions' )>
                <cfscript>
                  this.idCountryID = 0;
                  this.sCountryName = "";
                  this.sISOCode = "";
                  this.sDHLCode = "";
                  this.iErrorID = "";
                </cfscript>
                // The following functions are the setters and getters. offering us a better way to get
                // at the contents of the object
                // Getters
                <cffunction name="getID" displayname="Get ID" returntype="numeric" output="false" hint="This returns the ID of the current item.">
                  <cfreturn this.idCountryID>
                </cffunction>
                <cffunction name="getsCountryName" displayname="Get sCountryName" returntype="string" output="false" hint="This gets the sCountryName value of this item.">
                  <cfreturn this.sCountryName>
                </cffunction>
                <cffunction name="getsISOCode" displayname="Get sISOCode" returntype="string" output="false" hint="This gets the sISOCode value of this item.">
                  <cfreturn this.sISOCode>
                </cffunction>
                <cffunction name="getsDHLCode" displayname="Get sDHLCode" returntype="string" output="false" hint="This gets the sDHLCode value of this item.">
                  <cfreturn this.sDHLCode>
                </cffunction>
                <cffunction name="iError" displayname="Get iError" returntype="numeric" output="false" hint="This returns the iError of the current item.">
                  <cfreturn this.iError>
                </cffunction>
                // Setters
                <cffunction name="setID" displayname="Set ID" returntype="boolean" output="false" hint="This sets the ID value of this item.">
                  <cfargument name="idCountryID" required="true" type="numeric" displayname="ID" hint="The ID to use.">
                  <cfset this.idCountryID = arguments.idCountryID>
                  <cfreturn true>
                </cffunction>
                <cffunction name="setsCountryName" displayname="Set sCountryName" returntype="boolean" output="false" hint="This sets the sCountryName value of this item.">
                  <cfargument name="sCountryName" required="true" type="string" displayname="sCountryName" hint="The sCountryName to use.">
                  <cfset this.sCountryName = arguments.sCountryName>
                  <cfreturn true>
                </cffunction>
                <cffunction name="setsISOCode" displayname="Set sISOCode" returntype="boolean" output="false" hint="This sets the sISOCode value of this item.">
                  <cfargument name="sISOCode" required="true" type="string" displayname="sISOCode" hint="The sISOCode to use.">
                  <cfset this.sISOCode = arguments.sISOCode>
                  <cfreturn true>
                </cffunction>
                <cffunction name="setsDHLCode" displayname="Set sDHLCode" returntype="boolean" output="false" hint="This sets the sDHLCode value of this item.">
                  <cfargument name="sDHLCode" required="true" type="string" displayname="sDHLCode" hint="The sDHLCode to use.">
                  <cfset this.sDHLCode = arguments.sDHLCode>
                  <cfreturn true>
                </cffunction>
                // Clear, to empty out the contents of this object
                <cffunction name="clear" displayname="Clear items Details" returntype="boolean" output="false" hint="Clears out all of the items details.">
                  <cfscript>
                   this.sISOCode = "";
                   this.sDHLCode = "";
                   this.iErrorID = "";
                  </cfscript>
                  <cfreturn true>
                </cffunction>
                // The following functions deal with the load, save and deleting of objects
                // Load
                <cffunction name="load" displayname="Load items details" returntype="numeric" output="false" hint="This loads in all the information about an item.">
                  <cfset rc = this.clear()>
                  // First of all we need to get the name of the data source we are going to be using
                  <cfscript>
                  objDS = CreateObject("component","nec.com.system.settings");
                  sDatasource = objDS.getDatasource();
                </cfscript>
                  // Check to see if it exists
                  <cftry>
                   <cfquery name="checkID" datasource="#sDatasource#">
                    SELECT idCountryID
                    FROM tblCountry
                    WHERE idCountryID = #this.idCountryID#
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("load: checkID: '#this.idCountryID#' #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  <cfif not checkID.recordCount>
                   <cfscript>
                     if(isDefined("session.afr")){
                      whichOne = "#session.afr.getsAFRNumber()#";
                     } else {
                      whichOne = "";
                     iErrorID = objError.addError("A Country with that id doesn't exists.[#this.idCountryID#][#whichOne#]");
                    </cfscript>
                   <cfreturn iErrorID>
                  </cfif>
                  // If we got past all then then load in the details
                  <cftry>
                    SELECT idCountryID, RTRIM(sCountryName) as sCountryName, RTRIM(sISOCode) as sISOCode, RTRIM(sDHLCode) as sDHLCode
                    FROM tblCountry
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  <cfset this.idCountryID = get.idCountryID>
                  <cfset this.sCountryName = get.sCountryName>
                  <cfset this.sISOCode = get.sISOCode>
                  <cfset this.sDHLCode = get.sDHLCode>
                  <cfreturn true>
                </cffunction>
                // Save
                <cffunction name="save" displayname="Save items Details" returntype="numeric" output="false" hint="Saves (to some source) the current details for the ID of the item.">
                  <cfscript>
                </cfscript>
                  // Now check to see if ithat ID exists
                  <cftry>
                    SELECT idCountryID
                    FROM tblCountry
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("save: checkID: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  // If it doesn't exist, then add the record, otherwise update the record
                   <cfreturn this.add()>
                  <cfelse>
                   <cfreturn this.update()>
                  </cfif>
                </cffunction>
                // Add
                <cffunction name="add" displayname="Add Country" returntype="numeric" output="false" hint="This adds a Country.">
                  // Check to see if that a different item isn't already using the same unique details
                  <cftry>
                   <cfquery name="checkUnique" datasource="#sDatasource#">
                    SELECT idCountryID
                    FROM tblCountry
                    WHERE sCountryName = '#this.objFunctions.scrubText(this.sCountryName)#'
                    OR sISOCOde = '#this.objFunctions.scrubText(this.sISOcode)#'
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("add: checkUnique: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  <cfif checkUnique.recordCount>
                   <cfscript>
                     iErrorID = objError.addError("A Country with that name or ISO code already exists. idCountryID=#checkUnique.idCountryID#");
                    </cfscript>
                   <cfreturn iErrorID>
                  </cfif>
                  <cftry>
                   <cfquery name="add" datasource="#sDatasource#">
                    SET nocount on
                    INSERT INTO tblCountry(sCountryName, sISOCode, sDHLCode)
                    VALUES('#this.objFunctions.scrubText(this.sCountryName)#','#this.objFunctions.scrubText(t his.sISOCode)#','#this.objFunctions.scrubText(this.sDHLCode)#')
                    SELECT @@identity as autoID
                    SET nocount off
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("add: add: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  <cfreturn add.autoID>
                </cffunction>
                // Update
                <cffunction name="update" displayname="Update Country" returntype="numeric" output="false" hint="This updates a Country record.">
                  <cftry>
                    SELECT idCountryID
                    FROM tblCountry
                    WHERE (sCountryName = '#this.objFunctions.scrubText(this.sCountryName)#'
                    OR sISOCOde = '#this.objFunctions.scrubText(this.sISOcode)#')
                    AND idCountryID <> #this.idCountryID#
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("update: checkUnique: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                   <cfscript>
                     iErrorID = objError.addError("Another Country with that name already exists. idCountryID=#checkUnique.idCountryID#");
                    </cfscript>
                   <cfreturn iErrorID>
                  </cfif>
                  // Attempt to update the record to the datasource
                  // if this fails for any reason then we submit an error message
                  // to the error component and return the ID of the error
                  <cftry>
                   <cfquery name="update" datasource="#sDatasource#">
                    UPDATE tblCountry
                    SET sCountryName = '#this.objFunctions.scrubText(this.sCountryName)#',
                    sISOCode = '#this.objFunctions.scrubText(this.sISOCode)#',
                    sDHLCode = '#this.objFunctions.scrubText(this.sDHLCode)#'
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("update: update: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                </cffunction>
                // Delete
                <cffunction name="delete" displayname="Delete Country" returntype="numeric" output="false" hint="This deletes a Country record.">
                  <cfscript>
                </cfscript>
                  <cftry>
                    SELECT idCountryID
                    FROM tblCountry
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("delete: checkID: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                   <cfscript>
                     iErrorID = objError.addError("A Country with that id doesn't exists, delete failed.");
                    </cfscript>
                   <cfreturn iErrorID>
                  </cfif>
                  // Now check to see if there are any dependancies, if so we can't delete the item
                  <cftry>
                   <cfquery name="checkDependancies" datasource="#sDatasource#">
                    SELECT idCountry
                    FROM tblAddress
                    WHERE idCountry = #this.idCountryID#
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("delete: checkDependancies: idCountry: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                  <cfif checkDependancies.recordCount>
                   <cfscript>
                     iErrorID = objError.addError("That Country is being used by an address, delete failed.");
                    </cfscript>
                   <cfreturn iErrorID>
                  </cfif>
                  // Now attempt to remove the record.
                  <cftry>
                   <cfquery name="delete" datasource="#sDatasource#">
                    DELETE FROM tblCountry
                   </cfquery>
                   <cfcatch>
                    <cfscript>
                     iErrorID = objError.addError("delete: delete: #cfcatch.detail#");
                    </cfscript>
                    <cfreturn iErrorID>
                   </cfcatch>
                  </cftry>
                </cffunction>
                </cfcomponent>
                • 5. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
                  The problem is in the load function.  There is a return true at the end of the function.  The returntype of the function is set to numeric.  True is not numeric so it will throw an error.
                  • 6. Re: The value returned from the load function is not of type numeric  errors after migration to Coldfusion 11
                    That did the trick
                    Thank you for pointing me in the right direction.
