1 Reply Latest reply on Feb 19, 2015 1:33 AM by try67
    Text field not updating ?
    BSisson
      I have a very simple script that was almost lifted from this forum.
      The only changes I made were to make in generic so I could push it up to the document script level and call the same script for multiple buttons.
      I have two input text boxes  (Section+"NewDefect" and Section+"NewDefectExport")
      They get put into textVal, exportVal and stuffed into the list called (Section+"Issues") when a button is pushed
      This works fine....  It should as it was lifted from this forum
      My Issue.... I want to clear/reset/blank the input text fields when I am done....
      I have tried textVal   = null, textVal   = " ", textVal.value   = null
      getting the pointer again and setting it to " " ie :    var rawtextVal   = this.getField(Section+"NewDefect"); rawtextVal = " "
      Why can't I blank/clear those text fields?
      function add_btn(Section)
          var textVal   = this.getField(Section+"NewDefect").value;
          var exportVal = this.getField(Section+"NewDefectExport").value;
          var listFld   = this.getField(Section+"Issues");
          if (textVal)
              listFld.insertItemAt(textVal, exportVal, 0);   // Everything works GREAT to here...
          textVal     = " ";
          exportVal = " ";        // these seem to be ignored no matter what I do. a println shows they are being executed
        • 1. Re: Text field not updating ?
          To change the value of a field you have to access it directly. Your variables are just holding the value of the field, they're not a reference to it.
          You can change the value of a field like this:
          this.getField("Field name").value = "new value;
          Or like this:
          var f = this.getField("Field name");
          f.value = "new value";
          But not like this:
          var v = this.getField("Field name").value;
          v = "new value";
